楼主: 123456abc
求助自动数字递增
发表于 2010-5-17 09:53:00 | 显示全部楼层
xshrimp兄,能否帮忙改下如下形式的递增,
ABC-50-123
ABC-50-123-131
ABC-50-123-131-123212
其中123数字为递增,也就是第三组数字递增,谢谢!
明经网友  发表于 2010-5-17 11:02:00
(defun c:bhao (/   var1      basetext selflag    tabnum enttext enttext0
        basevbatext      bgf bgL    valuea
        valueb   enttexta   seltexta enttexta0  prefix suffix fixnumstr i fixnum prefixflag fixflag
        basetexta fixnumlength
  (setq var1 (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq enttext
  (entget
    (setq seltext (car (entsel "选择基数\n")))
  (setq enttext0 (cdr (assoc 0 enttext)))
  (setq basetext (cond
     ((= "TEXT" enttext0)
      (cdr (assoc 1 enttext))
     ((= "INSERT" enttext0)
      (cdr (assoc 1 (entget (entnext seltext))))
     (t 1)
  (setq selflag 1
 tabnum 1
  (setq fixnumstr "0123456789")
  (setq prefix "");;正确判断经下三组数据
  (setq fixnum "")
  (setq suffix "")
  (setq i 0)
  (while (not  (wcmatch fixnumstr (strcat "*" (chr (vl-string-elt basetext i)) "*")))
    (setq prefix (strcat prefix (chr (vl-string-elt basetext i))))
    (setq i (1+ i)))
  (setq basetexta (vl-string-left-trim prefix basetext))
  (setq i 0)
  (setq fixflag 1)
;;;  (princ "IT'S OK1!")
  (while fixflag
    (if (wcmatch fixnumstr
   (strcat "*" (chr (vl-string-elt basetexta i)) "*")
      (setq fixnum (strcat fixnum (chr (vl-string-elt basetexta i))))
    (setq i (1+ i))
    (if (= i (strlen basetexta))
      (setq fixflag nil)
  ;;;(princ "IT'S OK!")
  (setq suffix (vl-string-left-trim fixnum basetexta))
  (setq valueb fixnum)
  (setq fixnumlength (strlen fixnum))
    ;;;(princ "IT'S OK1!")
  (while (= 1 selflag)
    (princ "本次编号:")
    (setq valueb (atoi valueb))
    (princ valueb)
    (setq valueb (+ tabnum valueb))
    (setq valueb (itoa valueb))
    (while (<(strlen valueb) fixnumlength)
      (setq valueb (strcat "0" valueb)))
         (setq basetext (strcat prefix valueb suffix))
    (setq seltexta (entsel "选择要修改的编号\n"))
    (if seltexta
      (setq enttexta (entget (car seltexta)))
      (setq selflag nil)
    (if selflag
 (setq enttexta0 (cdr (assoc 0 enttexta)))
 (setq enttexta
        (cond
   ((= "TEXT" enttexta0)
    (subst (cons 1 basetext)
    (assoc 1 enttexta)
    enttexta
   ((= "INSERT" enttexta0)
    (assoc 1 (entget (entnext (car seltexta))))
   (t 1)
 (entmod enttexta)
 (entupd (car seltexta))
    )     ;end while entcn
使用道具
发表于 2010-5-17 11:31:00 | 显示全部楼层
  (setq enttext
  (entget
     (t 1)
  (setq selflag 1
 tabnum 1
  (setq prefix "");正确判断以下三个数据
  (setq fixnum "")
  (setq suffix "")
  (setq i 0)
    (setq i (1+ i)))
  (setq i 0)
  (setq fixflag 1)
  (while fixflag
    (setq i (1+ i))
      (setq fixflag nil)
    (princ "本次编号:")
    (princ valueb)
    (if seltexta
      (setq selflag nil)
    (if selflag
 (setq enttexta
        (cond
    (assoc 1 enttexta)
    enttexta
   (t 1)
 (entmod enttexta)
    )     ;end while entcn
发表于 2010-5-17 15:30:00 | 显示全部楼层
谢谢楼上的热心,好像达不到我想要的效果!
发表于 2010-5-18 14:53:00 | 显示全部楼层
各位,能否帮忙改下如下形式的递增,
ABC-50-123
ABC-50-123-131
发表于 2010-5-18 16:42:00 | 显示全部楼层
楼主自己修改一下就可以了啊.
适合
ABC-50-123
ABC-50-123-131
其中123数字为递增
  1. (defun c:test ()
  2.   (setq i (getint "\输入起始数字:"))
  3.   (while (setq txt (ssget ":S" '((0 . "TEXT"))))
  4.   (setq txt (ssname txt 0) dat (entget txt) str (cdr (assoc 1 dat))  )
  5.   ;(setq str "ABC-001-50-2A2") ;test
  6.   (setq strlst (strParse Str "-"))
  7.   (setq numws (strlen (nth 2 strlst)))
  8.   (setq txt_num_new (itoa i ))
  9.   (repeat (- numws (strlen txt_num_new))
  10.       (setq txt_num_new  (strcat "0" txt_num_new))
  11.   )
  12.   (setq nuwstr (StrUnParse (append (list (car strlst))(list (cadr strlst))(list txt_num_new) (cdddr  strlst)) "-"))
  13.   (entmod    (subst      (cons 1  nuwstr  )      (assoc 1 dat)      Dat  ) )
  14.   (setq i (1+ i))
  15.   )
  16. )
发表于 2010-5-19 11:18:00 | 显示全部楼层
谢谢xshrimp兄的关注,程序正是我想要的,但是有一个疑问,我对比了一下你之前的程序,只有一处是不一样的,就是这句“(nth 2 strlst)))”中的数字不一样,你之前的程序数字是1,递增的是第二组数字,你给我改的程序数字是2,递增的是第三组数字,我把程序中的数改成3,试了一下发现第四组数字并没有递增,递增的仍然是第三组数字,我想说的是改哪个地方,可以自由更改,来满足不同组的递增,谢谢!
GMT+8, 2025-7-30 13:46 , Processed in 0.244732 second(s), 18 queries , Gzip On.
