查看: 2018|回复: 1
谁能帮我改改
发表于 2010-4-26 17:30:00 | 显示全部楼层 |阅读模式
我不会用intersectwith这个函数
谁知道的给我改改下面的代码
Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        '对话
        Dim values As TypedValue() = New TypedValue() {New TypedValue(DxfCode.Start, "POLYLINE")}
        Dim sfilter As New SelectionFilter(values)
        '选择多段线
        Dim optsel As New PromptSelectionOptions
        optsel.MessageForAdding = " 请选择多段线"
        Dim relsel As PromptSelectionResult = ed.GetSelection(optsel, sfilter)
        Dim sest As SelectionSet = relsel.Value
        Dim line1ids As ObjectId() = sest.GetObjectIds
        '选择图层多段线
        Dim ft As TypedValue() = New TypedValue() {New TypedValue(DxfCode.Start, "POLYLINE"), New TypedValue(DxfCode.LayerName, "DGX")}
        Dim sr As PromptSelectionResult = ed.SelectAll(New SelectionFilter(ft))
        Dim ssest As SelectionSet = relsel.Value
        Dim line2ids As ObjectId() = ssest.GetObjectIds
        Using trans As Transaction = db.TransactionManager.StartTransaction()
            Dim pointlist As List(Of Point3dCollection)
            For Each _polyline As Polyline In sest
                For Each _polyline2 As Polyline In ssest
                    If _polyline.IntersectWith(_polyline2) = True Then
                        pointlist.Add(_polyline.IntersectWith(_polyline2))
                    End If
                Next
            Next
        End Using
发表于 2010-4-29 16:28:00 | 显示全部楼层
PolyLine有IntersectWith 方法吗?
GMT+8, 2025-5-2 01:15 , Processed in 0.158011 second(s), 24 queries , Gzip On.
