(defun c:tjl() ;分类统计线长度 (setq lss (ssget '((0 . "line")))) (setq i 0) (setq biao '()) (repeat (sslength lss) (setq a (ssname lss i)) (setq a10 (cdr (assoc 10 (entget a)))) (setq a11 (cdr (assoc 11 (entget a)))) (setq dist (distance a10 a11)) (if (assoc dist biao) (progn (setq bbb (assoc dist biao)) (setq bbbb (list dist (1+ (cadr bbb)))) (setq biao (subst bbbb (assoc dist biao) biao)) ) (setq biao (append biao (list (list dist 1)))) ) (setq i (1+ i)) ) (foreach x biao (princ "\n")(princ x) )(princ))
输出到文件里
自己copy吧
(defun c:tjl() ;分类统计线长度 (setq lss (ssget '((0 . "line")))) (setq i 0) (setq biao '()) (repeat (sslength lss) (setq a (ssname lss i)) (setq a10 (cdr (assoc 10 (entget a)))) (setq a11 (cdr (assoc 11 (entget a)))) (setq dist (distance a10 a11)) (if (assoc dist biao) (progn (setq bbb (assoc dist biao)) (setq bbbb (list dist (1+ (cadr bbb)))) (setq biao (subst bbbb (assoc dist biao) biao)) ) (setq biao (append biao (list (list dist 1)))) ) (setq i (1+ i)) ) (setq file (open "c:\\temp.txt" "w")) (foreach x biao (princ (car x) file)(princ "\t" file)(princ (cadr x) file)(princ "\n" file) ) (close file)(princ))
太感谢你了,
有一个小问题,数量太多的时候,会导致同样长的线,出现几次。
1375.0 108650.0 24621400.0 3768445.0 15121475.0 56400.0 56445.0 281400.0 138646.71 2445.0 281400.0 18
試試,改一下
(setq dist (rtos (distance a10 a11) 2 1))
或
(setq dist (atof (rtos (distance a10 a11) 2 1)))
改成(setq dist (rtos (distance a10 a11) 2 1))就可以了,谢谢!
本版积分规则 发表回复 回帖后跳转到最后一页
GMT+8, 2025-7-30 01:46 , Processed in 0.167929 second(s), 26 queries , Gzip On.
