查看: 8284|回复: 25
[基础] how to vector image in dcl
发表于 2010-4-8 19:28:00 | 显示全部楼层 |阅读模式
function XML() {
    [native code]
发表于 2010-4-8 20:07:00 | 显示全部楼层
See the help of lisp function VECTOR_IMAGE and FILL_IMAGE.
User : (vector_image X1 Y1 X2 Y2 COLOR)
User : (fill_image X1 Y1 X2 Y2 COLOR)
发表于 2010-4-9 02:14:00 | 显示全部楼层
Are you Indian?
Can not see,Please do not use "Firefox" Browser posted.
 楼主| 发表于 2010-4-9 17:34:00 | 显示全部楼层
function XML() {
    [native code]
发表于 2010-4-9 18:33:00 | 显示全部楼层
he is 鬼佬?
发表于 2010-4-11 11:27:00 | 显示全部楼层
 楼主| 发表于 2010-4-12 15:06:00 | 显示全部楼层
dear sir
yes im india
 楼主| 发表于 2010-4-12 15:11:00 | 显示全部楼层
  1. The following is a quoteDead catStatements in 2010-4-11 11:27:00:
复制代码
dear sir
thx for reply
see attached file what actual I want
发表于 2010-4-12 15:48:00 | 显示全部楼层
 From AutoCAD help file
Draws a vector in the currently active dialog box image
(vector_image x1 y1 x2 y2 color)
This function draws a vector in the currently active dialog box image (opened by start_image) from the point (x1,y1) to (x2,y2). The origin (0,0) is the upper-left corner of the image. You can obtain the coordinates of the lower-right corner by calling the dimension functions (dimx_tile and dimy_tile).
Arguments
x1
X coordinate of the first point.
y1
Y coordinate of the first point.
x2
X coordinate of the second point.
y2
Y coordinate of the second point.
color
An AutoCAD color number, or one of the logical color numbers shown in the following table:
Symbolic names for color attribute
Color numberADI mnemonicDescription
-2BGLCOLORCurrent background of the AutoCAD drawing area
-15DBGLCOLORCurrent dialog box background color
-16DFGLCOLORCurrent dialog box foreground color (text)
-18LINELCOLORCurrent dialog box line color
Return Values
An integer representing the color of the vector.
Examples
(setq color -2) ;; color of AutoCAD drawing area
(vector_image
 0
 0
 (dimx_tile "slide_tile")
 (dimy_tile "slide_tile")
 color
(end_image)
发表于 2010-4-12 17:18:00 | 显示全部楼层
请说中文!
GMT+8, 2025-7-4 12:16 , Processed in 0.187315 second(s), 28 queries , Gzip On.
