查看: 1910|回复: 1
c#里怎么连接CAD?^_^万分感谢
发表于 2010-4-7 15:08:00 | 显示全部楼层 |阅读模式
在VB里的连接CAD函数怎么移植到C#下啊?万分感谢
 Sub 连接AutoCAD()
        On Error Resume Next
        Acadapp = GetObject(, "AutoCAD.Application")
        If Err.Number Then
            Err.Clear()
            Acadapp = CreateObject("AutoCAD.Application")
            If Err.Number Then
                MsgBox("不能运行AutoCAD,请检查是否安装了AutoCAD 2004")
                Exit Sub
            End If
        End If
        Acadapp.Visible = True '界面可视
        AcadApp.WindowState = autocad.AcWindowState.acMax '界面最大化
        AppActivate(Acadapp.Caption) '显示AutoCAD界面
    End Sub
发表于 2010-7-30 12:47:00 | 显示全部楼层
class  AutoCADConnector: IDisposable
      public  AcadApplication _application;
      private bool _initialized;
      private bool _disposed;
      public   AutoCADConnector()
         try
            // Upon creation, attempt to retrieve running instance
            _application = (AcadApplication)Marshal.GetActiveObject("AutoCAD.Application.16");
         catch
            try
               // Create an instance and set flag to indicate this
               _application =  new  AcadApplicationClass();
               _initialized = true;
            catch
               throw;
      // If the user doesn't call Dispose, the
      // garbage collector will upon destruction
      ~AutoCADConnector()
         Dispose(false);
      public AcadApplication Application
         get
            // Return our internal instance of AutoCAD
            return _application;
      // This is the user-callable version of Dispose.
      // It calls our internal version and removes the
      // object from the garbage collector's queue.
      public void Dispose()
         Dispose(true);
        GC.SuppressFinalize(this);
      // This version of Dispose gets called by our
      // destructor.
      protected virtual void Dispose(bool disposing)
         // If we created our AutoCAD instance, call its
         // Quit method to avoid leaking memory.
          if (!this._disposed && _initialized)
              try
                  if (Marshal.GetActiveObject("AutoCAD.Application.16").Equals(this._application))
                      _application.Quit();
             catch
          _disposed = true;
GMT+8, 2025-6-2 03:50 , Processed in 0.166068 second(s), 24 queries , Gzip On.
