- 积分
- 16570
- 明经币
- 个
- 注册时间
- 2003-4-26
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2011-2-15 20:31:23
显示全部楼层
;~~~~~~~~~~~~~~~~~~~get 取得图元串列资讯~~~~~~~~~~~~~~~
(defun c:get(/ )
(setq a(entsel))
(setq b(entget (car a)))
;~~~~~~~~~~~~~~~~~~~~将所有dimension 炸开~~~~~~~~~~~~~~~~~~~~
(defun c:d1(/ss1 )
(setq ss1(ssget "X" '((0 . "DIMENSION"))))
(command "\n")
(command "explode" ss1 "")
(defun c:qa(/ inputcode c)
(setq inputcode(getint "\n输入欲查询assoc code: "))
(setq c(assoc inputcode b))
;~~~~~~~~~~~~~~~~~~~~副涵式 二点间求中点座标~~~~~~~~~~~~~~~~~~~~
(defun getmidpt(pt1 pt2) ;取得中点座标
(setq mx (/ (+ (car pt1) (car pt2)) 2))
(setq my (/ (+ (cadr pt1) (cadr pt2)) 2))
(list mx my)
;~~~~~~~~~~~~~~~~~~~~查询角度~~~~~~~~~~~~~~~~~~~~
(defun c:pi(/ a b)
(setq a(getangle "请输入十进位角度值:"))
(setq b(/ a 3.14159))
(princ (strcat "\n 此角度为" (rtos a) "径" (rtos b) "pi") )
(prin1 )
;~~~~~~~~~~~~~~~~~~~~快速缩放~~~~~~~~~~~~~~~~~~~~
(defun c:zs()(command "zoom" "0.8x")(prin1))
(defun c:zz()(command "zoom" "1.25x")(prin1))
(defun c:za()(command "zoom" "a")(prin1))
(defun c:ze()(command "zoom" "e")(prin1))
(defun c:zw()(command "zoom" "w"))
(prompt "直接输入 ZS,ZZ,ZA,ZE 作 ZOOM 快速缩放")
(prin1)
;~~~~~~~~~~~~~~~~~~~~十字游标角度调整~~~~~~~~~~~~~~~~~~~~
(defun c:0() (command "snapang" 0)(prin1))
(defun c:15()(command "snapang" 15)(prin1))
(defun c:30()(command "snapang" 30)(prin1))
(defun c:45()(command "'snapang" 45)(prin1))
(defun c:60()(command "'snapang" 60)(prin1))
(defun c:75()(command "'snapang" 75)(prin1))
(prompt "直接输入 0、15、30、45、60、75十字游标角度调整")
(prin1)
;~~~~~~~~~~~~~~~~~~~~求点位并标柱~~~~~~~~~~~~~~~~~~~~
(defun c:q(/ pa xx yy osnap_v ldf npa )
(setq pa (getpoint "输入角点:"))
(setq xx (getdist "\n纵距x:"))
(setq yy (getdist "\n横距y:"))
(setq osnap_v(getvar "osmode")) ;取出osnap值
(setvar "osmode" 0 );并且关闭 以免影响lisp绘图
(setq ldf(getvar "clayer") )
(setq npa(list (+ (car pa) xx) (+ (cadr pa) yy) ))
(command "point" npa)
(command "layer" "s" "h-dim" "" )
(if (> xx 0 )
(if(> yy 0)
(command "dimlinear" pa npa "h" (polar npa 90 50));Horizontal
(command "dimlinear" pa npa "v" (polar npa 0 50));vertical
(command "dimlinear" pa npa "h" (polar npa 270 50));Horizontal
);end if (yy)
(if (< yy 0)
(command "dimlinear" pa npa "v" (polar npa 180 50));vertical
(command "dimlinear" pa npa "h" (polar npa 90 50));vertical
);end if (yy)
(setvar "osmode" osnap_v );恢复原来抓点模式设定
(setvar "clayer" ldf );还原原来之lyaer设定
(prin1)
;~~~~~~~~~~~~~~~~~~~~快速断点(bf)~~~~~~~~~~~~~~~~~~~~
(defun c:BF(/ ob Bp)
(setq ob(entsel "选取断裂物件:"))
(setq Bp(getpoint "输入断裂点:"))
(command "BREAK" ob "F" BP BP)(prin1))
(prin1)
;~~~~~~~~~~~~~~~~~~快速断点(bf)~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
;~~~~~~~~~~~~~~~~~~档名路径产生器(n)~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
(defun c:n(/ NAME NAME1 tpoint1 tpoint2 path nodwg);(/ name name1)
(setq name(getvar "dwgname") )
(setq name1(strcase name) );变成大写
(setq nlens(strlen name1));新字串长度
(setq nodwg(substr name1 1 (- nlens 4) ))
(setq path(getvar "dwgprefix"))
(setq tpoint1 '(353 52.2 0));file name
(setq tpoint2 '(349 0.72 0));path diretory
(command "text" tpoint1 2.5 "" nodwg "")
(command "text" tpoint2 1.5 "" path "")
(prompt name1)
(prompt path)
(prin1)
;(setq ss1(ssget "X" '((0 . "DIMENSION")))) (0 . "MTEXT")
;~~~~~~~~~~~~~~~~~~改变所有尺寸型式(cd)~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
(defun c:cd()
(setq dimstyle(getstring "请输入dimension style:" ))
(setq ss(ssget "X" '((0 . "DIMENSION"))))
(setq i 0)
(repeat (sslength ss)
(setq ssn(ssname ss i))
(setq ssdata(entget ssn))
(setq old_style (assoc 3 ssdata))
(setq new_style (cons 3 dimstyle))
(setq ssdata (subst new_style old_style ssdata))
(entmod ssdata)
(setq i (1+ i))
;~~~~~~~~~~~~~~~~~~改变所有尺寸型式(cd)~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ );end repeat 1
(setq p5 p2); 字串变数p5
);progn
);progn
);end if b
);end defun |
