查看: 2537|回复: 5
[基础] [求助]CAD左上角图标和CAD2008能改动吗?
发表于 2010-2-26 06:15:00 | 显示全部楼层 |阅读模式
如下图所示:
发表于 2010-2-26 08:33:00 | 显示全部楼层
当然可以,在ACAD.DLL文件中
 楼主| 发表于 2010-3-6 06:35:00 | 显示全部楼层
谢谢ZHAOWCHANG!
能不能把操作步骤说一下!能不能连同CAD2008这几个字也一同去掉呢?
发表于 2010-4-29 15:15:00 | 显示全部楼层
对CAD2009而言,在哪里呢?好像在CAD2009的安装目录下找不到ACAD.DLL
发表于 2010-4-30 00:26:00 | 显示全部楼层
可以改的 , 用VBA
Option Explicit
Public Declare Function SetWindowText Lib "user32" Alias "SetWindowTextA" (ByVal Hwnd As Long, ByVal lpString As String) As Long
Private Declare Function LoadImage Lib "user32" Alias "LoadImageA" (ByVal hInst As Long, ByVal lpsz As String, ByVal un1 As Long, ByVal n1 As Long, ByVal n2 As Long, ByVal un2 As Long) As Long
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal Hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, lParam As Any) As Long
Private Const WM_SETICON = &H80
Private Const IMAGE_ICON = 1
Private Const LR_LOADFROMFILE = &H10
Public Sub ChangeCADCaption()
Dim strCaption As String
strCaption = "ZWCAD 2009i 专业版"
SetWindowText Application.Hwnd, strCaption
End Sub
Public Sub SetIcon()
Dim hIcon As Long
Dim FileName As String
FileName = "cad.ico"
'FileName 图标文件, Hwnd ACAD应用程序的句柄
hIcon = LoadImage(0&, FileName, IMAGE_ICON, 16, 16, LR_LOADFROMFILE)
If hIcon <> 0 Then
Call SendMessage(Hwnd, WM_SETICON, 0, ByVal hIcon)
End If
End Sub
 楼主| 发表于 2010-4-30 06:37:00 | 显示全部楼层
fujiang发表于2010-4-30 0:26:00可以改的 , 用VBAOption ExplicitPublic Declare Function SetWindowText Lib \"user32\" Alias \"SetWindowTextA\" (ByVal Hwnd As Long, ByVal lpString As String) As LongPrivate Declare
谢谢你!我没用过VBA,完全看不懂!不知这个程序如何运行?能否说详细点……
GMT+8, 2025-7-29 23:44 , Processed in 0.192251 second(s), 27 queries , Gzip On.
