查看: 2206|回复: 4
求救:特性对话框变为英文,无选择时还是汉字
发表于 2010-2-2 13:46:00 | 显示全部楼层 |阅读模式
我用的是AutoCAD2005,这两天突然发现特性对话框变为英文,无选择时还是汉字,这是怎么回事儿呢?
发表于 2010-2-3 21:03:00 | 显示全部楼层
 wedding dresses beautiful shoulders and neck by wedding dress choosing spaghetti straps.wedding dresses These have a young and modern look and are very attractive on the right girl.
Shape Styles Sleeve Styles Neckline Styles Stylomatic bridesmaid dress
Halterneck tops expose 2009 bridesmaid dresses beautiful shoulders and well-toned wedding dresses arms, whilemother of bride dresses the continuity mother of bride dresses of line makes you look taller if you are petite.wedding Gowns The halterneck top echoes the lower half of the dress, so if you have 2009 wedding dresses slim hips the halterneck will be an excellent counterpoint.bridesmaid dresses There are many different variations on the halterneck style; collar with straps ,wedding dresses single strap wrapping round the back of the neck,gloves factory covered or wedding dresses exposed V to the bust. A halterneck style can also hide that little cheap wedding dresses underarm "pouch" that we discount wedding dresses are sometimes prone wedding dresses to!
Like the bias bridal Gown cut but with a straight weft and vertical seams,bridal gown the Column dress hugswedding dress the figure and looks great on tall, willowy women. This is the one to glove give you that catwalk look! The unbroken mother of bride dressesline will also work well for a more petite figure.
wedding dress style guide
Beautiful asymmetric strap designs will distract from squarediscount wedding dresses shoulders, but there is a danger mittens that bringing the eye to the unusual diagonal look will prom dress emphasize the shoulders too.
akes tall brides look taller.discount wedding dresses If you have a marvellous figure and want gloves to show it off, a figure-hugging dress might be preferable, but it is difficult to find too much wedding dress wrong with the rincess style,flower girl dresses which is probably why
If you have  a slim-hipped figure and a full bustmother of bride dresses, the Full Skirt shape will balance top and bottom perfectly, giving you that "fairytale bride" look. This style or rincess are generally discount wedding dressesthought of as the most romantic shapes.
A bias-cut dress hugs the hips,prom dresses so if you are fuller 2009 bridesmaid dresses in the hip, bridal gownavoid this style.mittens It will show off a cheap wedding dresses perfect curvy figure, but if there are flower girl dresses curves where you don't want them, they'll show too!
Use a strapless bra with wedding dresses spaghetti straps so that there are no bridal gown distractions. Keep angular couture wedding dresses shoulders or large arms covered up. Spaghetti straps also emphasize the neck, so be sure it looks good if you wedding dresses choose them.gloves You can also use a necklace effectively wedding Gowns to compliment the straps. discount wedding dress
This is another fairytale wholesale wedding dresses look. Starting wedding dress the waistline gloves factorybeneath the bust works well for smaller busts, and the long line makes petite brides look taller. For the ultimate romantic style, this one won't let you down. The Empire prom dress line with an A-line skirt will also do a marvellous job at bridal dresses concealing wider hips. prom dressesAn Empire bridesmaid dresses Line with a column skirt adds height and balances a smaller bust bridal gowns.
This is a fitted bodice shape with an A-line skirt. It hugs the waistwedding Gowns, so it flatters slim waistlines while making the most of the bust. If you have wider hips, leather gloves2009 wedding dressesthe A-Line will cover them up effectively
Perfect fitbridal gowns
发表于 2010-2-3 23:29:00 | 显示全部楼层
adpu其实我也奇怪...明明看的时候是中文...
但是想打开,或者编辑时.却变成乱码日文了...
发表于 2010-2-4 09:42:00 | 显示全部楼层
3楼说的和楼主还不是一个事儿吧。
楼主的情形似乎是指“属性”对话框自身的提示信息在汉字和英文间的变换。这个,没有遇见过,听着也觉得比较的离奇。
3楼是说图形里的些文字,在图形里看着是正常的汉字中文,编辑其内容是就是一堆乱码。这样的情况,比较可能是在不同代码页间转移形成的。可以试试将那些文字原位置复制下,删除原来的那组(即在删除时提示选择响应以"P"),新创建的这组有可能是正常的。
发表于 2010-2-23 23:46:00 | 显示全部楼层
好东西支持
GMT+8, 2025-5-7 17:43 , Processed in 0.172180 second(s), 24 queries , Gzip On.
