- 积分
- 24588
- 明经币
- 个
- 注册时间
- 2004-3-17
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
经常要做些选择集的过滤器,然而.Net的过滤器写起来真的很繁琐
所以。。。
ResultList类,原创是TonyT,:) - using System;
- using System.Collections.Generic;
- using System.Text;
- using Autodesk.AutoCAD.DatabaseServices;
- using Autodesk.AutoCAD.Runtime;
- using Autodesk.AutoCAD.EditorInput;
- using Autodesk.AutoCAD.Geometry;
- namespace TlsCad.Collections
- /// <summary>
- /// TypedValue Collection
- /// </summary>
- public class ResultList : List<TypedValue>, IFormattable
- public ResultList(){ }
- public ResultList(IEnumerable<TypedValue> values) : base(values)
- public ResultList(ResultBuffer rb) : base(rb.AsArray())
- #region Add
- public void Add(int typeCode, object obj)
- base.Add(new TypedValue(typeCode, obj));
- public void Add(LispDataType type, object obj)
- base.Add(new TypedValue((int)type, obj));
- public void Add(DxfCode type, object obj)
- #endregion
- #region Convert
- public static implicit operator TypedValue[](ResultList rlst)
- return rlst.ToArray();
- public static implicit operator ResultBuffer(ResultList rlst)
- return new ResultBuffer(rlst.ToArray());
- public static implicit operator SelectionFilter(ResultList rlst)
- return new SelectionFilter(rlst.ToArray());
- #endregion
- #region IFormattable 成员
- public override string ToString()
- var rb = new ResultBuffer(ToArray());
- return rb.ToString();
- string IFormattable.ToString(string format, IFormatProvider formatProvider)
- return rb.ToString(format, formatProvider);
- #endregion
ResultTree类,原创飞狐 - using System;
- using System.Linq;
- using System.Collections;
- public enum ResultTreeType
- Node,
- List,
- DottedPair,
- RelationalOperator,
- LogicalOperator,
- /// <summary>
- /// TypedValue Tree
- /// </summary>
- public class ResultTree : IEnumerable<ResultTree>, IFormattable
- ResultTreeType _treeType;
- ResultTree _owner;
- TypedValue _typedValue;
- List<ResultTree> _lst = new List<ResultTree>();
- static readonly List<string> _relationalOperatorNames =
- new List<string> { "not", "and", "or", "xor" };
- #region Properties
- public ResultTree this[int index]
- get
- if (_lst.Count == 0)
- if(index == 0)
- return this;
- else
- if (index >= 0 && index < _lst.Count)
- return _lst[index];
- return null;
- public ResultTreeType TreeType
- get { return _treeType; }
- public TypedValue TypedValue
- get { return _typedValue; }
- public short TypeCode
- get { return _typedValue.TypeCode; }
- public LispDataType LispDataType
- get { return (LispDataType)TypeCode; }
- public DxfCode DxfCode
- get { return (DxfCode)TypeCode; }
- public object Value
- get { return _typedValue.Value; }
- public T GetValue<T>()
- return (T)_typedValue.Value;
- #endregion
- #region Constructor
- public ResultTree()
- _treeType = ResultTreeType.Node;
- public ResultTree(TypedValue value)
- :this()
- _typedValue = value;
- public ResultTree(int typeCode, object obj)
- : this(new TypedValue(typeCode, obj))
- public ResultTree(LispDataType type, object obj)
- : this(new TypedValue((int)type, obj))
- public ResultTree(DxfCode type, object obj)
- public ResultTree(string operatorContext)
- operatorContext = operatorContext.ToLower();
- _treeType =
- _relationalOperatorNames.Contains(operatorContext) ?
- ResultTreeType.RelationalOperator : ResultTreeType.LogicalOperator;
- _typedValue = new TypedValue(-4, operatorContext);
- public ResultTree(ResultTreeType type)
- _treeType = type;
- private enum ResultNodeType
- Node,
- ListBegin,
- ListEnd,
- DottedPairEnd,
- LogicalOperator,
- RelationalOperatorBegin,
- RelationalOperatorEnd,
- private ResultNodeType GetNodeType(TypedValue tvalue, out ResultTree rt)
- short typeCode = tvalue.TypeCode;
- object value = tvalue.Value;
- rt = null;
- if (typeCode == -4)
- string s = ((string)value).ToLower();
- if(s[0] == '<' && _relationalOperatorNames.Contains(s.Substring(1)))
- rt = new ResultTree(s.Substring(1));
- return ResultNodeType.RelationalOperatorBegin;
- else if(s[s.Length - 1] == '>' && _relationalOperatorNames.Contains(s.Substring(0, s.Length - 1)))
- return ResultNodeType.RelationalOperatorEnd;
- else
- rt = new ResultTree(s);
- return ResultNodeType.LogicalOperator;
- else if(typeCode == (short)LispDataType.ListBegin)
- rt = new ResultTree(ResultTreeType.List);
- return ResultNodeType.ListBegin;
- else if(typeCode == (short)LispDataType.ListEnd)
- return ResultNodeType.ListEnd;
- else if(typeCode == (short)LispDataType.DottedPair)
- return ResultNodeType.DottedPairEnd;
- else
- rt = new ResultTree(tvalue);
- return ResultNodeType.Node;
- public ResultTree(ResultBuffer rb)
- ResultTree rt = this;
- foreach (TypedValue tv in rb)
- ResultTree trt;
- switch (GetNodeType(tv, out trt))
- case ResultNodeType.LogicalOperator:
- case ResultNodeType.RelationalOperatorBegin:
- case ResultNodeType.ListBegin:
- rt = rt.Add(trt);
- break;
- case ResultNodeType.DottedPairEnd:
- rt._treeType = ResultTreeType.DottedPair;
- rt = rt._owner;
- break;
- case ResultNodeType.RelationalOperatorEnd:
- case ResultNodeType.ListEnd:
- rt = rt._owner;
- break;
- default:
- rt.Add(trt);
- if (rt._treeType == ResultTreeType.RelationalOperator)
- rt = rt._owner;
- break;
- if (_lst.Count == 1)
- rt = _lst[0];
- _lst.Remove(rt);
- _lst.AddRange(rt);
- _treeType = rt._treeType;
- _typedValue = rt._typedValue;
- #endregion
- #region Set
- public void Set(int typeCode, object obj)
- _typedValue = new TypedValue(typeCode, obj);
- public void Set(LispDataType type, object obj)
- _typedValue = new TypedValue((int)type, obj);
- public void Set(DxfCode type, object obj)
- public void Set(int typeCode)
- _typedValue = new TypedValue(typeCode);
- public void Set(LispDataType type)
- _typedValue = new TypedValue((int)type);
- public void Set(DxfCode type)
- #endregion
- #region Add
- public ResultTree Add(TypedValue value)
- return Add(new ResultTree(value));
- public ResultTree Add(int typeCode, object obj)
- return Add(new ResultTree(typeCode, obj));
- public ResultTree Add(LispDataType type, object obj)
- return Add(new ResultTree(type, obj));
- public ResultTree Add(DxfCode type, object obj)
- public ResultTree Add(ResultTree rt)
- rt._owner = this;
- _lst.Add(rt);
- return rt;
- #region Add LispData
- public ResultTree Add(short value)
- return Add(new ResultTree(LispDataType.Int16, value));
- public ResultTree Add(int value)
- return Add(new ResultTree(LispDataType.Int32, value));
- public ResultTree Add(double value)
- return Add(new ResultTree(LispDataType.Double, value));
- public ResultTree Add(string value)
- return Add(new ResultTree(LispDataType.Text, value));
- public ResultTree Add(Point2d value)
- return Add(new ResultTree(LispDataType.Point2d, value));
- public ResultTree Add(Point3d value)
- return Add(new ResultTree(LispDataType.Point3d, value));
- public ResultTree Add(ObjectId value)
- return Add(new ResultTree(LispDataType.ObjectId, value));
- public ResultTree Add(SelectionSet value)
- return Add(new ResultTree(LispDataType.SelectionSet, value));
- //public void Add(ResultType type, params object[] values)
- // ResultTree rt = new ResultTree(type);
- // foreach (object value in values)
- // if (value is short)
- // rt.Add((short)value);
- // else if (value is int)
- // rt.Add((int)value);
- // else if (value is double)
- // rt.Add((double)value);
- // else if (value is string)
- // rt.Add((string)value);
- // else if (value is Point2d)
- // rt.Add((Point2d)value);
- // else if (value is Point3d)
- // rt.Add((Point3d)value);
- // else if (value is ObjectId)
- // rt.Add((ObjectId)value);
- // else if (value is SelectionSet)
- // rt.Add((SelectionSet)value);
- #endregion
- #endregion
- #region Convert
- private void GetValues(List<TypedValue> values)
- switch (_treeType)
- case ResultTreeType.Node:
- values.Add(_typedValue);
- else
- _lst.ForEach(rtree => rtree.GetValues(values));
- break;
- case ResultTreeType.List:
- values.Add(new TypedValue((int)LispDataType.ListBegin));
- values.Add(new TypedValue((int)LispDataType.ListEnd));
- break;
- case ResultTreeType.DottedPair:
- values.Add(new TypedValue((int)LispDataType.DottedPair));
- break;
- case ResultTreeType.LogicalOperator:
- break;
- case ResultTreeType.RelationalOperator:
- values.Add(new TypedValue(-4, "<" + _typedValue.Value));
- values.Add(new TypedValue(-4, _typedValue.Value + ">"));
- break;
- public TypedValue[] ToArray()
- List<TypedValue> values = new List<TypedValue>();
- GetValues(values);
- return values.ToArray();
- public static implicit operator SelectionFilter(ResultTree rtree)
- return new SelectionFilter(rtree.ToArray());
- public static implicit operator ResultBuffer(ResultTree rtree)
- return new ResultBuffer(rtree.ToArray());
- #endregion
- #region RelationalOperator
- private void MakeRelationalOperator(string operatorContext, ResultTree res)
- if (_treeType == ResultTreeType.RelationalOperator && _typedValue.Value.ToString() == operatorContext)
- res._lst.AddRange(_lst);
- else
- res.Add(this);
- public static ResultTree operator !(ResultTree rt1)
- ResultTree rt = new ResultTree("not") { rt1 };
- return rt;
- public static ResultTree operator &(ResultTree rt1, ResultTree rt2)
- ResultTree rt = new ResultTree("and");
- rt1.MakeRelationalOperator("and", rt);
- rt2.MakeRelationalOperator("and", rt);
- return rt;
- public static ResultTree operator |(ResultTree rt1, ResultTree rt2)
- ResultTree rt = new ResultTree("or");
- rt1.MakeRelationalOperator("or", rt);
- rt2.MakeRelationalOperator("or", rt);
- return rt;
- public static ResultTree operator ^(ResultTree rt1, ResultTree rt2)
- return
- new ResultTree("xor")
- rt1,
- rt2
- #endregion
- #endregion
- #region IEnumerable<ResultTree> 成员
- #region IEnumerable 成员
- IEnumerator IEnumerable.GetEnumerator()
- return _lst.GetEnumerator();
- #endregion
- IEnumerator<ResultTree> IEnumerable<ResultTree>.GetEnumerator()
- #endregion
扩展方法 -
- using System;
- using TlsCad.Collections;
- namespace TlsCad.ExtendMethods
- public static class ResultBufferEx
- public static ResultList ToList(this ResultBuffer rb)
- return new ResultList(rb);
- public static ResultTree ToTree(this ResultBuffer rb)
- return new ResultTree(rb);
示例代码 - [CommandMethod("t9")]
- public static void Test9()
- Document doc = Application.DocumentManager.MdiActiveDocument;
- Database db = doc.Database;
- Editor ed = doc.Editor;
- PromptSelectionResult res1 =
- ed.SelectAll(
- new ResultTree
- new ResultTree(">,>,*")
- {10, new Point3d()}
- new ResultTree("<,<,*")
- {10, new Point3d(10,10,0)}
- PromptSelectionResult res2 =
- ed.SelectAll(
- new ResultList
- {-4, ">,>,*"},
- {10, new Point3d()},
- {-4, "<,<,*"},
- PromptSelectionResult res3 =
- ed.SelectAll(
- new ResultTree("or")
- new ResultTree("and")
- {0, "Line"},
- {8, "01"}
- {0, "Circle"},
- {8, "02"}
- PromptSelectionResult res4 =
- ed.SelectAll(
- new ResultList
- {-4, "<or"},
- {-4, "<and"},
- {0, "Line"},
- {8, "01"},
- {-4, "and>"},
- {-4, "<and"},
- {0, "Circle"},
- {8, "02"},
- {-4, "and>"},
- {-4, "or>"}
- [CommandMethod("t10")]
- public static void Test10()
- PromptEntityResult res = ed.GetEntity("Select a Entity:");
- using (DBTransaction tr = new DBTransaction())
- tr.OpenRegAppTable(OpenMode.ForWrite);
- tr.RegApp("MyApp");
- Entity ent = tr.GetObject(res.ObjectId, OpenMode.ForWrite) as Entity;
- ent.XData =
- new ResultList
- {1001, "MyApp"},
- {1000, "This is a Test"},
- {DxfCode.ExtendedDataInteger16, 12}
- [CommandMethod("t11")]
- public static void Test11()
- PromptEntityResult res1 = ed.GetEntity("\nSelect a Entity:");
- InvokeArx.CmdEcho = false;
- InvokeArx.Command(
- false,
- new ResultTree
- "break",
- new ResultTree(ResultType.List)
- res1.ObjectId,
- res1.PickedPoint
- res1.PickedPoint
- InvokeArx.CmdEcho = true;
- [LispFunction("lsptest1")]
- public static ResultBuffer LTest1(ResultBuffer rb)
- ResultTree rtree =
- 1,
- new ResultTree(ResultType.DottedPair)
- 10,
- new Point3d(10, 10, 0)
- return rtree;
参与人数 1 | 威望 +1 |
明经币 +2 |
金钱 +20 |
贡献 +5 |
激情 +5 |
收起
理由
ahlzl
| + 1 |
+ 2 |
+ 20 |
+ 5 |
+ 5 |
【精华】好程序 |
