查看: 1628|回复: 1
[求助]关于断面面积
发表于 2009-12-16 12:26:00 | 显示全部楼层 |阅读模式
Pt(0) = 0: Pt(1) = (HS + h10(i)) / 2 + (i - 1) * ucs
     ThisDrawing.SendCommand "-Boundary" & vbCr & Pt(0) & "," & Pt(1) & vbCr & vbCr
       Set lwpLineObj = ThisDrawing.ModelSpace.Item(ThisDrawing.ModelSpace.Count - 1)
        S = lwpLineObj.Area
        lwpLineObj.Delete
      '写面积
    PMJ(0) = 4: PMJ(1) = -6 + h10(i) + (i - 1) * ucs: PMJ(2) = 0
    hMJ = 0.6
    deltah = h10(i) - HS
    If deltah > 0 Then
       Aw = Format(deltah, "0.000"): mtextmj = "Aw=" & S
    ElseIf deltah < 0 Then
       At = Format(Abs(deltah), "0.000"): mtextmj = "At=" & S
    End If
     ThisDrawing.ActiveLayer = courtlay4
    Set mjtext = ThisDrawing.ModelSpace.AddText(mtextmj, PMJ, hMJ)
     Next i
绘制横断面,面积是借用网上的,对某些部分不理解
逐行运行都可以的,总体运行就出错:
1、多段线并不删除
2、没有显示需要的数据,都是0
请各位指教!
 楼主| 发表于 2009-12-22 11:36:00 | 显示全部楼层
咋没人回答啊,我自己解决了。
1、用regen
2、用zoomwindow
GMT+8, 2025-6-3 21:33 , Processed in 0.223900 second(s), 23 queries , Gzip On.
