查看: 2337|回复: 4
请问如何制做中文的立体字呢?
发表于 2003-6-27 11:08:00 | 显示全部楼层 |阅读模式
我本想将字炸开然后再用拉伸命令进行拉伸,却拉伸不出来,还有字体的选择,如果是TXT的字体便是问号……谢谢
发表于 2003-6-27 11:30:00 | 显示全部楼层
一般TXT字体不支持中文,做立体字参考以下:
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=5635
发表于 2003-6-27 12:46:00 | 显示全部楼层
;;;    这是很久前在xdcad中发表的,其中用到xdrx_api
;;;    功能:把字转为立体3D字
;;;    修改EXPRESSTOOL中的TXTEXP.LSP使用 By:龙龙仔
;;;    虽配合EXPRESSTOOL 及 XDRX_API15
;;;    注意:只能转TTF字型,非TTF字型转为"细明体"
;;;    By Dominic Panholzer
;;;    TXTEXP.LSP
;;;    Copyright ?1999 by Autodesk, Inc.
;;;    Your use of this software is governed by the terms and conditions of the
;;;    License Agreement you accepted prior to installation of this software.
;;;    Please note that pursuant to the License Agreement for this software,
;;;    "[c]opying of this computer program or its documentation except as
;;;    permitted by this License is copyright infringement under the laws of
;;;    your country.  If you copy this computer program without permission of
;;;    Autodesk, you are violating the law."
;;;    AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;;    AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;;    MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
;;;    DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;;    UNINTERRUPTED OR ERROR FREE.
;;;    Use, duplication, or disclosure by the U.S. Government is subject to
;;;    restrictions set forth in FAR 52.227-19 (Commercial Computer
;;;    Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;;    (Rights in Technical Data and Computer Software), as applicable.
;;;  External Functions:
;;;     ACET-ERROR-INIT           --> ACETUTIL.FAS   Intializes bonus error routine
;;;     ACET-ERROR-RESTORE        --> ACETUTIL.FAS   Restores old error routine
;;;     ACET-GEOM-ZOOM-FOR-SELECT --> ACETUTIL.FAS   Zoom boundry to include points given
;;;     ACET-LAYER-LOCKED         --> ACETUTIL.FAS   Checks to see if layer is locked
;;;     ACET-GEOM-PIXEL-UNIT      --> ACETUTIL.FAS   Size of pixel in drawing units
;;;     ACET-GEOM-TEXTBOX         --> ACETUTIL.FAS   Returns the textbox for any text
;;;     ACET-GEOM-MIDPOINT        --> ACETUTIL.FAS   Returns midpoint between two points
;;;     ACET-GEOM-VIEW-POINTS     --> ACETUTIL.FAS   Returns corner points of screen or viewport
;;;     ACET-STR-FORMAT           --> ACETUTIL.ARX   String builder
;;;     ACET-WMFIN                --> ACETUTIL.FAS   Brings in WMF file
(defun TXTEXP (SS      /       GRPLST  GETGNAME               BLKNM   GLST
               GDICT   VIEW    UPLFT   TMPFIL  TBX     TMPFIL  CNT
               PT1     PT2     ENT     TXT     TXTYP   PTLST   ZM
               LOCKED  GNAM
  (ACET-ERROR-INIT
    (list
      (list "cmdecho"  0          "highlight"                1
            "osmode"   0          "Mirrtext" 1                "limcheck"
            0
      t
;;; --------------------- GROUP LIST FUNCTION ----------------------
;;;   This function will return a list of all the group names in the
;;;   drawing and their entity names in the form:
;;;   ((<ename1> . <name1>) ... (<enamex> . <namex>))
  (defun ACET-TXTEXP-GRPLST (/ GRP ITM NAM ENT GLST)
    (setq GRP (dictsearch (namedobjdict) "ACAD_GROUP"))
    (while (setq ITM (car GRP))                ; While edata item is available
      (if (= (car ITM) 3)                ; if the item is a group name
        (setq NAM  (cdr ITM)                ; get the name
              GRP  (cdr GRP)                ; shorten the edata
              ITM  (car GRP)                ; get the next item
              ENT  (cdr ITM)                ; which is the ename
              GLST                        ; store the ename and name
                   (if GLST
                     (append GLST (list (cons ENT NAM)))
        (setq GRP (cdr GRP))                ; else shorten the edata
    GLST                                ; return the list
;;; ------------------- GET GROUP NAME FUNCTION --------------------
;;;   This function returns a list of all the group names in GLST
;;;   where ENT is a member. The list has the same form as GLST
  (defun ACET-TXTEXP-GETGNAME (ENT GLST / GRP GDATA NAM NLST)
    (if        (and GLST (listp GLST))
        (foreach GRP GLST
          (setq GDATA (entget (car GRP)))
          (foreach ITM GDATA                ; step through the edata
            (if        (and
                  (= (car ITM) 340)        ; if the item is a entity name
                  (eq (setq NAM (cdr ITM)) ENT)
                                        ; and the ename being looked for
              (setq NLST                ; store the ename and name
                     (if NLST
                       (append NLST (list (cons (car GRP) (cdr GRP))))
    NLST
;;;                          MAIN PROGRAM
  (if (and                                ; Are we in plan view?
        (equal (car (getvar "viewdir")) 0 0.00001)
        (equal (cadr (getvar "viewdir")) 0 0.00001)
        (> (caddr (getvar "viewdir")) 0)
      (setq GLST  (ACET-TXTEXP-GRPLST)        ; Get all the groups in drawing
            GDICT (if GLST
            CNT          0
      ;; filter out the locked layers
      (if SS
        (setq SS (car (BNS_SS_MOD SS 1 t)))
      )                                        ;if
      ;; if we have anything left
      (if SS
          (setq CNT 0)                        ; Reset counter
          (while (setq ENT (ssname SS CNT))
                                        ; step through each object in set
            (and
              GLST                        ; if groups are present in the drawing
              (setq GNAM (ACET-TXTEXP-GETGNAME ENT GLST))
                                        ; and the text item is in one or more
              (foreach GRP GNAM                ; step through those groups
                (command "_.-group"
                         "_r"                ; and remove the text item
                         (cdr GRP)
                         ENT
            (setq TBX (ACET-GEOM-TEXTBOX (entget ENT) 0))
            ;; get textbox points
            (setq TBX (mapcar '(lambda (X)
                                 (trans X 1 0)
                                 ;; convert the points to WCS
                              TBX
            (setq PTLST (append PTLST TBX))
            ;; Build list of bounding box
            ;; points for text items selected
            (setq CNT (1+ CNT))                ; get the next text item
          )                                ; while
          (setq        PTLST (mapcar '(lambda (X)
                                 (trans X 0 1) ; convert all the points
                               )        ; to the current ucs
                              PTLST
          (if (setq ZM (ACET-GEOM-ZOOM-FOR-SELECT PTLST))
            ;; If current view does not contain
            (progn                        ; all bounding box points
              (setq ZM
                     (list
                       (list (- (caar ZM) (ACET-GEOM-PIXEL-UNIT))
                             ;; increase zoom area by
                             (- (cadar ZM) (ACET-GEOM-PIXEL-UNIT))
                             ;; one pixel width to
                             (caddar ZM) ; sure nothing will be lost
                       (list (+ (caadr ZM) (ACET-GEOM-PIXEL-UNIT))
                             (+ (cadadr ZM) (ACET-GEOM-PIXEL-UNIT))
                             (caddr (cadr ZM))
              (command "_.zoom" "_w" (car ZM) (cadr ZM))
              ;; zoom to include text objects
          (setq        VIEW   (ACET-GEOM-VIEW-POINTS)
                TMPFIL (strcat (getvar "tempprefix") "txtexp.wmf")
                PT1    (ACET-GEOM-MIDPOINT (car VIEW) (cadr VIEW))
                PT2    (list (car PT1) (cadadr VIEW))
          (if (ACET-LAYER-LOCKED (getvar "clayer"))
            ;; if current layer is locked
              (command "_.layer" "_unl" (getvar "clayer") "")
                                        ; unlock it
              (setq LOCKED t)
          (command "_.mirror"             SS              ""       PT1
                   PT2            "_y"     "_.WMFOUT"               TMPFIL
                   SS            ""
          (if (findfile TMPFIL)                ; Does WMF file exist?
              (command "_.ERASE" SS "")        ; erase the orignal text
              (setq SS (ACET-WMFIN TMPFIL)) ; insert the WMF file
              (command "_.mirror" SS "" PT1 PT2 "_y")
            )                                ;progn
          )                                ;if
          (if LOCKED
            (command "_.layer" "_lock" (getvar "clayer") "")
                                        ; relock if needed
          )                                ;if
          (if ZM
            (command "_.zoom" "_p")
          )                                ; Restore original view if needed
          (prompt (acet-str-format
                    "\n%1 text object(s) have been exploded to lines."
                    CNT
          (prompt "\nThe line objects have been placed on layer 0.")
    (prompt "\nView needs to be in plan (0 0 1).")
  )                                        ;if equal
  (ACET-ERROR-RESTORE)                        ; Retsore values
;;end txtexp
(arxload "xdrx_api15" NIL)
(setq HOLDECHO (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(if (not ACET-ERROR-INIT)
  (load "acetutil")
(if (not (tblsearch "style" "细明体"))
    (setq HOLDTEXTSTYLE (getvar "TEXTSTYLE"))
    (command "style" "细明体" "细明体" "0" "1" "0" "n" "n")
    (setvar "TEXTSTYLE" HOLDTEXTSTYLE)
    (setq HOLDTEXTSTYLE NIL)
(setvar "CMDECHO" HOLDECHO)
(setq HOLDECHO NIL)
(defun C:3D_TEXT (/ N A S1 S2 S3 SS SSS SSL SH LL LLL)
  (defun SUM (SSS LL/)
    (setq LLL (entnext LL))
    (ssadd LLL SSS)
    (ssadd (entlast) SSS)
    (while (not (eq LLL (entlast)))
      (ssadd LLL SSS)
      (setq LLL (entnext LLL))
  (setq        SS (ssget '((-4 . "<AND")
                    (-4 . "<OR")
                    (0 . "MTEXT")
                    (0 . "TEXT")
                    (-4 . "OR>")
                    (-4 . "<NOT")
                    (102 . "{ACAD_REACTORS")
                    (-4 . "NOT>")
                    (-4 . "AND>")
  (command "_.VIEW" "S" "3D_TEXT")
  (command "_.VIEW" "TOP")
  (setq SSL (sslength SS))
  (setq N 0)
  (repeat SSL
    (setq A (entget (ssname SS N)))
    (setq SH (cdr (assoc 3 (tblsearch "style" (cdr (assoc 7 A))))))
    (if        (/= "TTF" (strcase (substr SH (- (strlen SH) 2) 3)))
        (setq A (subst (cons 7 "细明体") (assoc 7 A) A))
        (entmod A)
    (setq N (1+ N))
  (TXTEXP SS)
  (command "_.VIEW" "R" "3D_TEXT")
  (command "_.VIEW" "D" "3D_TEXT")
  (setq LL (entlast))
  (setq S1 (ssget "p"))
  (command "_.region" S1 "")
  (SUM S1 LL)
  (command "_.union" S1 "")
  (setq S3 (ssget ""))
  (setq S1 (ssget "p" '((0 . "REGION"))))
  (command "_.select" S3 "")
  (setq S2 (ssget "p" '((0 . "OLYLINE"))))
  (setq N 0)
  (setq LL (entlast))
  (if S2
      (repeat (sslength S2)
        (command "_.explode" (ssname S2 N))
        (xdrx_curve_intersectbreak (ssget "p"))
        (setq N (1+ N))
      (SUM S1 LL)
  (setq LL (entlast))
  (if (not (equal (ssname S1 0) LL))
      (SUM S1 LL)
      (command "_.select" S1 "")
      (if (ssget "p" '((0 . "LINE")))
        (command "_.erase" (ssget "p" '((0 . "LINE"))) "")
  (command "_.extrude" S1 "")
(prompt "\nType 3d_text")
 楼主| 发表于 2003-6-27 13:39:00 | 显示全部楼层
头都大了,还有没有更简单一些的办法呢?
谢谢
发表于 2003-6-27 14:35:00 | 显示全部楼层
先用txtexp命令炸开文字,再剪去不需要的线,用region命令把文字改成面,就可拉伸为立体字了。
GMT+8, 2025-5-20 00:34 , Processed in 0.164587 second(s), 24 queries , Gzip On.
