帖子
查看: 1408|回复: 2
在实体相交判断中的问题
发表于 2009-11-15 19:01:00 | 显示全部楼层 |阅读模式
请教高手,实体有无交点能不能判断?应该怎么判断?
能不能用IntersectWith命令判断?
请高手指点
如果不能的话有没有办法自己编程实现?
发表于 2009-11-16 09:00:00 | 显示全部楼层
Sub Example_IntersectWith()
    ' This example creates a line and circle and finds the points at
    ' which they intersect.
    ' Create the line
    Dim lineObj As AcadLine
    Dim startPt(0 To 2) As Double
    Dim endPt(0 To 2) As Double
    startPt(0) = 1: startPt(1) = 1: startPt(2) = 0
    endPt(0) = 5: endPt(1) = 5: endPt(2) = 0
    Set lineObj = ThisDrawing.ModelSpace.AddLine(startPt, endPt)
    ' Create the circle
    Dim circleObj As AcadCircle
    Dim centerPt(0 To 2) As Double
    Dim radius As Double
    centerPt(0) = 8: centerPt(1) = 8: centerPt(2) = 0
    radius = 1
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius)
    ZoomAll
    ' Find the intersection points between the line and the circle
    Dim intPoints As Variant
    intPoints = lineObj.IntersectWith(circleObj, acExtendNone)
    ' Print all the intersection points
    Dim I As Integer, j As Integer, k As Integer
    Dim str As String
    If VarType(intPoints) <> vbEmpty Then
        For I = LBound(intPoints) To UBound(intPoints)
            str = "Intersection Point[" & k & "] is: " & intPoints(j) & "," & intPoints(j + 1) & "," & intPoints(j + 2)
            MsgBox str, , "IntersectWith Example"
            str = ""
            I = I + 2
            j = j + 3
            k = k + 1
        Next
    End If
End Sub
这个例子中,通过判断数组是否为空,来看看是否有交点!
 楼主| 发表于 2009-11-17 19:41:00 | 显示全部楼层
有没有实体相交判断的例子
GMT+8, 2025-7-12 18:10 , Processed in 0.210705 second(s), 23 queries , Gzip On.
