查看: 2162|回复: 2
[求助] WithEvents 事件
发表于 2009-10-11 10:55:00 | 显示全部楼层 |阅读模式
我在AutoCAD vba 模块中编写如下代码
Public WithEvents PLine As AcadLWPolyline       ' Use with Modified Event Example
Sub Example_Modified()
     ' This example creates a light weight polyline in model space and
     ' references the new PolyLine using the public variable (PLine) which
     ' is setup to intercept Modified events.
     ' This example then modifies the new object, triggering the code
     ' in the Modified event.
    Dim points(0 To 9) As Double
    ' Define the 2D polyline points
    points(0) = 1: points(1) = 1
    points(2) = 1: points(3) = 2
    points(4) = 2: points(5) = 2
    points(6) = 3: points(7) = 2
    points(8) = 4: points(9) = 4
    ' Create a light weight Polyline object in model space
    ' * Note: We are returning the new PolyLine object into a Module
    ' level variable.  This allows us to intercept events associated
    ' with that particular object.
    Set PLine = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    ThisDrawing.Application.ZoomAll
    ' Modify object to trigger event.
    ' * Note: The event code for the PolyLine modification will be triggered
    ' before we move forward and refresh the view, so the line will not
    ' appear red when the event message box is displayed
    PLine.Color = acRed
    ThisDrawing.Regen acAllViewports
End Sub
Private Sub PLine_Modified(ByVal pObject As AutoCAD.IAcadObject)
    ' This example intercepts an object's Modified event.
    ' This event is triggered when an object supporting this event is modified
    ' To trigger this code: Modifiy an object connected to this event
    ' * Note: By connected, we mean the object setup to intercept events using
    ' the VBA WithEvents statement
    ' Use the "pObject" variable to determine which object was modified
    MsgBox "You just modified an object with an ID of: " & pObject.ObjectID
End Sub
调试时提示 错误,怎末回事呀?
谢谢赐教!
 楼主| 发表于 2009-10-12 07:44:00 | 显示全部楼层
本人已经解决了:
1、在类中增加一个“eventclassmoduel”类,
2、把Public WithEvents PLine As AcadLWPolyline       ' Use with Modified Event Example
放入“eventclassmoduel”中
3、在标准模块中定义引用即可:dim x as eventclassmoduel
4、sub xxx()
’根据需要添加代码
end sub
发表于 2009-10-12 23:18:00 | 显示全部楼层
把整个代码放在thisdarwing里不就可以了,不用搞那么麻烦!
GMT+8, 2025-6-3 19:39 , Processed in 0.170344 second(s), 23 queries , Gzip On.
