查看: 3031|回复: 8
[求助]麻煩版主改一下lisp
发表于 2009-10-10 00:45:00 | 显示全部楼层 |阅读模式
我有lisp是自動畫沉頭的,但是程式是分段的
煩請版主可否改成輸入指令後再選擇沉頭大小
lisp源碼
(defun c:c3()
       (setq cmd(getvar "cmdecho"))
       (setvar "cmdecho" 0)
       (setq p1(getpoint "\n選擇擺放位置:"))
       (while (/= p1 nil)
       (command "circle" "none" p1 2)
       (command "change"(ENTLAST) "" "p"  "C" "6" "")
       (command "circle" "none" p1 3.5)
       (setq p1(getpoint "\nselect a point:")))
       (setvar "cmdecho" cmd)
(defun c:c4()
       (while (/= p1 nil)
       (command "circle" "none" p1 2.5)
       (command "circle" "none" p1 4)
(defun c:c5()
       (while (/= p1 nil)
       (command "circle" "none" p1 3)
       (command "circle" "none" p1 5)
(defun c:c6()
       (while (/= p1 nil)
       (command "circle" "none" p1 6)
(defun c:c8()
       (while (/= p1 nil)
       (command "circle" "none" p1 4.5)
       (command "circle" "none" p1 7)
(defun c:c10()
       (while (/= p1 nil)
       (command "circle" "none" p1 5.5)
       (command "circle" "none" p1 8)
发表于 2009-10-10 12:41:00 | 显示全部楼层
 楼主| 发表于 2009-10-11 01:33:00 | 显示全部楼层
謝謝版主熱情回答!!太感謝了
 楼主| 发表于 2009-10-12 20:24:00 | 显示全部楼层
可以再麻煩版主一下,可否按照沉頭一下改成螺絲孔的lisp
一樣是1.螺絲孔大小及中心位置輸入,
要有 M4 M5 M6 M8 M10 M12 M16 M30 M33
麻煩版主一下 !!
发表于 2009-10-12 20:49:00 | 显示全部楼层
 楼主| 发表于 2009-10-13 21:10:00 | 显示全部楼层
版主 本人使用好像出現錯誤
錯誤: 損壞的引數類型: numberp: nil
請版主再幫忙檢查一下
发表于 2010-6-14 13:53:00 | 显示全部楼层
參考看看
发表于 2010-6-20 15:23:00 | 显示全部楼层
(DEFUN C:TT1 ( / PB M H V P0 MI PO1 PT1 PT2 PT3 PT4 OLDL OLDOS)
(SETQ PB (GETPOINT "Base point 基准点 :")
      H (GETDIST "\nCoordinate of hor  水平座标 H = ")
      V (GETDIST "\nCoordinate of vert 垂直座标 V = ")
      M (GETDIST "\nDiameter of bolt  螺栓直径 M = ")
      PO (LIST (+ (CAR PB) H) (+ (CADR PB) V))
      MI (* M 0.85)
      PO1 (POLAR PO 1.0472 (* M 0.5))
      PT1 (POLAR PO 0 M) PT2 (POLAR PO PI M)
      AL1 (* (/ PI 2) 3) AL2 (/ PI 2)
      PT3 (POLAR PO AL1 M) PT4 (POLAR PO AL2 M)
      OLDL (GETVAR "CLAYER")  OLDOS (GETVAR "OSMODE"))
(SETVAR "BLIPMODE" 0) (SETVAR "CMDECHO" 0) (SETVAR "OSMODE" 0)
(COMMAND "LAYER" "M" "BLO" "" "CIRCLE" PO "D" MI
      "LAYER" "M" "THI" "" "ARC" PO1 "C" PO "A" 270
      "LAYER" "M" "CEN" "" "LINE" PT1 PT2 "" "LINE" PT3 PT4 "")
(SETVAR "CLAYER" OLDL)
(SETVAR "OSMODE" OLDOS)
(SETVAR "CMDECHO" 1)
(PRINC)
发表于 2011-9-12 23:00:12 | 显示全部楼层
ZZXXQQ  超级版主.超级hao版主
GMT+8, 2025-5-1 16:13 , Processed in 0.184376 second(s), 24 queries , Gzip On.
