查看: 2337|回复: 1
求实体与直线交点
发表于 2009-9-30 10:16:00 | 显示全部楼层 |阅读模式
请教一下,在cad中怎样求得实体与平面上一直线的交点坐标用
acdbInters函数只能求得两直线的交点..请高手帮忙急急急...........
发表于 2009-9-30 16:46:00 | 显示全部楼层
virtual Acad::ErrorStatus
intersectWith(
const AcDbEntity* pEnt,
AcDb::Intersect intType,
AcGePoint3dArray& points,
int thisGsMarker = 0,
int otherGsMarker = 0) const;
pEntInput entity with which "this" entity is to intersect
intTypeInput type of intersection requested
pointsOutput with the points of intersection appended
thisGsMarkerInput GS marker of subentity of "this" entity that's involved in the intersection operation. Use the 0 default if not applicable.
otherGsMarkerInput GS marker of subentity of the entity pointed to by pEnt that's involved in the intersection operation. Use the 0 default if not applicable.
GMT+8, 2025-5-2 01:03 , Processed in 0.164590 second(s), 23 queries , Gzip On.
