查看: 1486|回复: 0
dxf 文件中的坐标问题
发表于 2003-6-23 20:42:00 | 显示全部楼层 |阅读模式
我现在正在做一个vc6中读取显示dxf文件的程序。现遇到一个问题:
新建立一个空白文档,使用acadISO -Named Plot Styles.dwt模板
AutoCAD2004中用‘status命令可以看到
Model space uses       *Nothing*
Display shows          X:   89.8441   Y:   -0.1008
                       X: 1098.4186   Y:  519.5010
Insertion base is      X:    0.0000   Y:    0.0000   Z:    0.0000
Snap resolution is     X:   10.0000   Y:   10.0000
Grid spacing is        X:   10.0000   Y:   10.0000
Current space:        Model space
Current layout:       Model
Current layer:        "0"
Current color:        BYLAYER -- 7 (white)
Current linetype:     BYLAYER -- "Continuous"
Current lineweight:   BYLAYER
Current elevation:    0.0000  thickness:    0.0000
Fill on  Grid off  Ortho off  Qtext off  Snap off  Tablet off
Object snap modes:    Center, Endpoint, Intersection, Extension
Free dwg disk (C:) space: 980.8 MBytes
Free temp disk (C:) space: 980.8 MBytes
Free physical memory: 32.6 Mbytes (out of 127.5M).
Free swap file space: 78.8 Mbytes (out of 307.7M).
(注:由于使用的模板不一样,故display shows项的值也不一样)
另外用limmax命令可以看到420.0000,297.0000
那么dxf文件中有没有
项,如果没有这个项,那么我怎么来确定坐标?
请高手不吝赐教!
GMT+8, 2025-5-14 03:33 , Processed in 0.186722 second(s), 24 queries , Gzip On.
