查看: 1962|回复: 1
Spline应用一例
发表于 2009-9-29 12:01:00 | 显示全部楼层 |阅读模式
程序如下
  1. Sub lll()
  2.    Dim R, R1, H, Dn, THK, Dn1, THK1
  3.    Dim Alfa, baseAlfa
  4.    Dim Pt1(2) As Double, Pt2(2) As Double
  5.
  6.    Dim oLine As AcadLine
  7.    Dim oDivide
  8.    Dn = 2400: THK = 18
  9.    Dn1 = 530: THK1 = 18
  10.    R = Dn / 2 - THK
  11.    Dim oCircle As AcadCircle
  12.    'Set oCircle = ThisDrawing.ModelSpace.AddCircle(Pt1, R)
  13.    'Debug.Print oCircle.Circumference;
  14.    R1 = Dn1 / 2
  15.    Set oCircle = ThisDrawing.ModelSpace.AddCircle(Pt1, R1)
  16.    'Debug.Print oCircle.Circumference;
  17.    H = 250
  18.    Dim Pi
  19.    Pi = Atn(1) * 4
  20.    oDivide = 10
  21.    Dim splinePt() As Double, oSpline As AcadSpline
  22.    ReDim splinePt((360 / oDivide) * 3 + 2)
  23.    baseAlfa = oDivide * Pi / 180
  24.    Pt1(0) = 0
  25.    Pt2(0) = 2 * R1 * Pi
  26.    Set oLine = ThisDrawing.ModelSpace.AddLine(Pt1, Pt2)
  27.    Dim StartTangent, EndTangent
  28.    For n = 0 To 360 / oDivide
  29.      Alfa = n * baseAlfa
  30.      x = R1 * Cos(Alfa)
  31.      Pt1(0) = n * R1 * baseAlfa
  32.      Pt2(0) = Pt1(0)
  33.      ln = H + (R - Sqr(R ^ 2 - x ^ 2))
  34.      Pt2(0) = Pt1(0)
  35.      Pt2(1) = ln
  36.      'Debug.Print baseAlfa, Alfa, "x:" & Round(x, 5), "n=" & n, "Ln=" & ln
  37.      If n = 0 Then
  38.        StartTangent = Pt2
  39.      End If
  40.      Set oLine = ThisDrawing.ModelSpace.AddLine(Pt1, Pt2)
  41.      For jj = 0 To 2
  42.        splinePt(n * 3 + jj) = Pt2(jj)
  43.      Next jj
  44.    Next n
  45.    EndTangent = Pt2
  46.     Dim startTan(0 To 2) As Double
  47.     Dim endTan(0 To 2) As Double
  48.     'startTan(0) = 0: startTan(1) = 0.5: startTan(2) = 0
  49.     'endTan(0) = 0.5: endTan(1) = -0.5: endTan(2) = 0
  50.    Set oSpline = ThisDrawing.ModelSpace.AddSpline(splinePt, startTan, endTan)
  51. End Sub
发表于 2009-10-24 14:46:00 | 显示全部楼层
试了下,正确
GMT+8, 2025-6-3 19:56 , Processed in 0.175185 second(s), 30 queries , Gzip On.
