查看: 1710|回复: 3
Objectarx(求助)
发表于 2009-9-12 14:54:00 | 显示全部楼层 |阅读模式
请教各位大虾:我是新手,在调试中出现以下错误,但是不知如何解决。所对应的程序是在教程上拷贝过来的!我用的是VC6.0和ObjectArx2002。
代码如下:
AcDbObjectId CCreateEnt::CreatePolygon(AcGePoint2d ptCenter, int number, double radius, double rotation, double width)
 AcGePoint2dArray points;
 double angle=*CCalculation::PI()/(double)number;
 for (int i = 0; i < number; i++)
  AcGePoint2d pt;
  pt.x = ptCenter.x + radius * cos(i * angle);
  pt.y = ptCenter.y + radius * sin(i * angle);
  points.append(pt);
 AcDbObjectId polyId = CCreateEnt::CreatePolyline(points, width);
 // 将其闭合
 AcDbEntity *pEnt;
 acdbOpenAcDbEntity(pEnt, polyId, AcDb::kForWrite);
 AcDbPolyline *pPoly=AcDbPolyline::cast(pEnt);
 if (pPoly!= NULL)
  pPoly->setClosed(Adesk::kTrue);
 pEnt->close();
 CModifyEnt::Rotate(polyId, ptCenter, rotation);
 return polyId;
错误如下:
D:\TEST\CreateEnts\CreateEnt.cpp(153) : error C2653: 'CCalculation' : is not a class or namespace name
D:\TEST\CreateEnts\CreateEnt.cpp(153) : error C2065: 'PI' : undeclared identifier
D:\TEST\CreateEnts\CreateEnt.cpp(153) : error C2100: illegal indirection
D:\TEST\CreateEnts\CreateEnt.cpp(166) : error C2065: 'AcDbPolyline' : undeclared identifier
D:\TEST\CreateEnts\CreateEnt.cpp(166) : error C2065: 'pPoly' : undeclared identifier
D:\TEST\CreateEnts\CreateEnt.cpp(166) : error C2653: 'AcDbPolyline' : is not a class or namespace name
D:\TEST\CreateEnts\CreateEnt.cpp(166) : error C2065: 'cast' : undeclared identifier
D:\TEST\CreateEnts\CreateEnt.cpp(166) : error C2106: '=' : left operand must be l-value
D:\TEST\CreateEnts\CreateEnt.cpp(169) : error C2227: left of '->setClosed' must point to class/struct/union
D:\TEST\CreateEnts\CreateEnt.cpp(172) : error C2653: 'CModifyEnt' : is not a class or namespace name
D:\TEST\CreateEnts\CreateEnt.cpp(172) : error C2065: 'Rotate' : undeclared identifier
执行 cl.exe 时出错.
发表于 2009-9-13 05:31:00 | 显示全部楼层
function XML() {
    [native code]
发表于 2009-9-13 12:35:00 | 显示全部楼层
1,注意把包含的目录加上
2,把实体关闭不必那么麻烦
  1. AcDbEntity *pEnt;
  2. if ( Acad::eOk != acdbOpenAcDbEntity(pEnt, polyId, AcDb::kForWrite) )
  3. return;
  4. pEnt->setClosed(TRUE)//我不记得具体的方法是什么,你自己去查查看
  5. pEnt->close();
  6. //之后的代码自己加!
复制代码
发表于 2009-9-15 16:45:00 | 显示全部楼层
头文件都没include进来,程序怎么识别啊?
GMT+8, 2025-5-2 02:34 , Processed in 0.166239 second(s), 23 queries , Gzip On.
