- 积分
- 24588
- 明经币
- 个
- 注册时间
- 2004-3-17
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
楼主 |
发表于 2009-7-1 17:29:00
显示全部楼层
七、窗选打印
October 11, 2007
Plotting a window from AutoCAD using .NET
This post extends this previous post that dealt with driving a single-sheet AutoCAD plot by adding some code to handle selection and transformation of a window to plot.
First order of business was to allow the user to select the window to plot. For this I used the classic combination of Editor.GetPoint() for the first corner) and Editor.GetCorner() for the second. All well and good, but the points returned by these functions are in UCS (User Coordinate System) coordinates. Which meant that as it stood, the code would work just fine if (and only if) the view we were using to select the window was parallell with the World Coordinate System (and no additional UCS was in place). In order to deal with the very common scenario of either a UCS being used or the current modelspace view being orbited (etc.), we need to transform the current UCS coordinates into DCS, the Display Coordinate System.
Thankfully that's pretty easy: no need for matrices or anything, we simply use another old friend, acedTrans() (the ObjectARX equivalent of the (trans) function, for you LISPers out there). There isn't a direct equivalent for this function in the managed API (that I'm aware of), so we have to use P/Invoke to call the ObjectARX function. The technique is shown in this DevNote, for those of you that have access to the ADN website:
How to call acedTrans from .NET application?
Otherwise the changes to the original code are very minor: we need to set the extents of the window to plot and then set the plot type to "window", apparently in that order. AutoCAD complained when I initially made the calls in the opposite sequence.
Here's the C# code: - using Autodesk.AutoCAD.Runtime;
- using Autodesk.AutoCAD.ApplicationServices;
- using Autodesk.AutoCAD.DatabaseServices;
- using Autodesk.AutoCAD.EditorInput;
- using Autodesk.AutoCAD.PlottingServices;
- using Autodesk.AutoCAD.Geometry;
- using System.Runtime.InteropServices;
- using System;
- namespace PlottingApplication
- public class SimplePlottingCommands
- [DllImport("acad.exe",
- CallingConvention = CallingConvention.Cdecl,
- EntryPoint="acedTrans")
- static extern int acedTrans(
- double[] point,
- IntPtr fromRb,
- IntPtr toRb,
- int disp,
- double[] result
- [CommandMethod("winplot")]
- static public void WindowPlot()
- Document doc =
- Application.DocumentManager.MdiActiveDocument;
- Editor ed = doc.Editor;
- Database db = doc.Database;
- PromptPointOptions ppo =
- new PromptPointOptions(
- "\nSelect first corner of plot area: "
- ppo.AllowNone = false;
- PromptPointResult ppr =
- ed.GetPoint(ppo);
- if (ppr.Status != PromptStatus.OK)
- return;
- Point3d first = ppr.Value;
- PromptCornerOptions pco =
- new PromptCornerOptions(
- "\nSelect second corner of plot area: ",
- first
- ppr = ed.GetCorner(pco);
- return;
- Point3d second = ppr.Value;
- // Transform from UCS to DCS
- ResultBuffer rbFrom =
- new ResultBuffer(new TypedValue(5003, 1)),
- rbTo =
- new ResultBuffer(new TypedValue(5003, 2));
- double[] firres = new double[] { 0, 0, 0 };
- double[] secres = new double[] { 0, 0, 0 };
- // Transform the first point...
- acedTrans(
- first.ToArray(),
- rbFrom.UnmanagedObject,
- rbTo.UnmanagedObject,
- 0,
- firres
- // ... and the second
- acedTrans(
- second.ToArray(),
- 0,
- secres
- // We can safely drop the Z-coord at this stage
- Extents2d window =
- new Extents2d(
- firres[0],
- firres[1],
- secres[0],
- secres[1]
- Transaction tr =
- db.TransactionManager.StartTransaction();
- using (tr)
- // We'll be plotting the current layout
- BlockTableRecord btr =
- (BlockTableRecord)tr.GetObject(
- db.CurrentSpaceId,
- OpenMode.ForRead
- Layout lo =
- (Layout)tr.GetObject(
- btr.LayoutId,
- OpenMode.ForRead
- // We need a PlotInfo object
- // linked to the layout
- PlotInfo pi = new PlotInfo();
- pi.Layout = btr.LayoutId;
- // We need a PlotSettings object
- // based on the layout settings
- // which we then customize
- PlotSettings ps =
- new PlotSettings(lo.ModelType);
- ps.CopyFrom(lo);
- // The PlotSettingsValidator helps
- // create a valid PlotSettings object
- PlotSettingsValidator psv =
- PlotSettingsValidator.Current;
- // We'll plot the extents, centered and
- // scaled to fit
- psv.SetPlotWindowArea(ps, window);
- psv.SetPlotType(
- ps,
- Autodesk.AutoCAD.DatabaseServices.PlotType.Window
- psv.SetUseStandardScale(ps, true);
- psv.SetStdScaleType(ps, StdScaleType.ScaleToFit);
- psv.SetPlotCentered(ps, true);
- // We'll use the standard DWF PC3, as
- // for today we're just plotting to file
- psv.SetPlotConfigurationName(
- ps,
- "DWF6 ePlot.pc3",
- "ANSI_A_(8.50_x_11.00_Inches)"
- // We need to link the PlotInfo to the
- // PlotSettings and then validate it
- pi.OverrideSettings = ps;
- PlotInfoValidator piv =
- new PlotInfoValidator();
- piv.MediaMatchingPolicy =
- MatchingPolicy.MatchEnabled;
- piv.Validate(pi);
- // A PlotEngine does the actual plotting
- // (can also create one for Preview)
- if (PlotFactory.ProcessPlotState ==
- ProcessPlotState.NotPlotting)
- PlotEngine pe =
- PlotFactory.CreatePublishEngine();
- using (pe)
- // Create a Progress Dialog to provide info
- // and allow thej user to cancel
- PlotProgressDialog ppd =
- new PlotProgressDialog(false, 1, true);
- using (ppd)
- ppd.set_PlotMsgString(
- PlotMessageIndex.DialogTitle,
- "Custom Plot Progress"
- PlotMessageIndex.CancelJobButtonMessage,
- "Cancel Job"
- PlotMessageIndex.CancelSheetButtonMessage,
- "Cancel Sheet"
- PlotMessageIndex.SheetSetProgressCaption,
- "Sheet Set Progress"
- PlotMessageIndex.SheetProgressCaption,
- "Sheet Progress"
- ppd.LowerPlotProgressRange = 0;
- ppd.UpperPlotProgressRange = 100;
- ppd.PlotProgressPos = 0;
- // Let's start the plot, at last
- ppd.OnBeginPlot();
- ppd.IsVisible = true;
- pe.BeginPlot(ppd, null);
- // We'll be plotting a single document
- pe.BeginDocument(
- pi,
- doc.Name,
- null,
- 1,
- true, // Let's plot to file
- "c:\\test-output"
- // Which contains a single sheet
- ppd.OnBeginSheet();
- ppd.LowerSheetProgressRange = 0;
- ppd.UpperSheetProgressRange = 100;
- ppd.SheetProgressPos = 0;
- PlotPageInfo ppi = new PlotPageInfo();
- pe.BeginPage(
- ppi,
- pi,
- true,
- null
- pe.BeginGenerateGraphics(null);
- pe.EndGenerateGraphics(null);
- // Finish the sheet
- pe.EndPage(null);
- ppd.SheetProgressPos = 100;
- ppd.OnEndSheet();
- // Finish the document
- pe.EndDocument(null);
- // And finish the plot
- ppd.PlotProgressPos = 100;
- ppd.OnEndPlot();
- pe.EndPlot(null);
- else
- ed.WriteMessage(
- "\nAnother plot is in progress."
