帖子
查看: 2473|回复: 0
autocadmap短线检查源码
发表于 2009-6-19 14:53:00 | 显示全部楼层 |阅读模式
//-------------------------------------短线检查----------------------------------------------------------
void CleanupShortLine()
 SetCurLayer(_T("checklayer"),250);
 ade_id cleanupVarId = ADE_NULLID;          // variable ID
 ade_id cleanupModelId = ADE_NULLID;        // clean ID
   ade_id cleanupactionVarId = ADE_NULLID;    //variable ID
 ads_name ss;                               // selection set
 long qty = 0;                              // quantity数量
 long totalqty=0;                           //所有错误的总和
 int type = 0;                              // clean error group type
 int subtype = 0;                           // clean error group subtype
 int done = 0;                              //是否完成清理工作
 int resultCode = 0;
 CString str;
 //给cleanup变量分配内存,变量初始化为它们的缺省值,使用tpm_varalloc.
 cleanupVarId = tpm_varalloc();
    cleanupactionVarId=tpm_varalloc();
 //为cleanup模型分配内存,使用 tpm_cleanalloc.
 cleanupModelId = tpm_cleanalloc();
 if( ! cleanupVarId || ! cleanupModelId ||!cleanupactionVarId)
  acutPrintf(_T("\n内存分配失败."));
  tpm_varfree(cleanupVarId);
  tpm_cleanfree(cleanupModelId);
  return;
 tpm_cleanactionlistins(cleanupVarId,1,1,cleanupactionVarId);//必须在tpm_cleaninit前调用
 tpm_cleanactionlistins(cleanupVarId,2,256,cleanupactionVarId);//必须在tpm_cleaninit前调用
 if(acedSSGet(_T("X"),NULL,NULL,NULL,ss)!= RTNORM)//第一个参数为NULL为自由选,“X”为全选
  acutPrintf(_T("\n获取选择集失败!"));
  tpm_varfree(cleanupactionVarId);
  return;
 // 初始化一个目标选择集命名为 ss进行清理工作
 tpm_cleaninit(cleanupModelId, cleanupVarId, ss);//初始化清理模型
 resultCode = tpm_cleanstart(cleanupModelId);//开始清理进程
 if( resultCode != RTNORM )
  acutPrintf(_T("\n清理工作启动失败."));
  return;
 // Count errors by group type and subtype
 while ( ! done)
  resultCode = tpm_cleangroupnext(cleanupModelId);
  if ( resultCode == RTNORM )
   if (tpm_cleancomplete(cleanupModelId) == TRUE )
    done = 1;
   else
    type = tpm_cleangrouptype(cleanupModelId);
    subtype = tpm_cleangroupsubtype(cleanupModelId);
    tpm_cleangroupqty(cleanupModelId, &qty);
    tpm_cleangroupmark(cleanupModelId);
//         tpm_cleangroupfix(cleanupModelId);
    if(qty>0)
     acutPrintf(_T("\n组类型:%d,子类型:%d,错误数目:%
d"),type,subtype,qty);
     totalqty+=qty;
   } // else
  } // if
  else
   acutPrintf(_T("\n没有要清理的对象"));
 } // while
 resultCode = tpm_cleanend(cleanupModelId);//完成清理进程并更新图形,修复被tpm_cleanerrorfix指定的
要修复的错误
    resultCode = acedSSFree(ss);//最后释放选择集
 tpm_cleanfree(cleanupModelId);//释放清理模型
 tpm_varfree(cleanupVarId);//释放配置变量
 tpm_varfree(cleanupactionVarId);//释放配置变量
 if(totalqty==0)
  str.Format(_T("\n恭喜!未找到任何错误。"));
 else
     str.Format(_T("短线错误%d处"),totalqty);
 acedAlert(str);
GMT+8, 2025-6-10 16:18 , Processed in 0.160548 second(s), 23 queries , Gzip On.
