查看: 4310|回复: 3
[求助]关于属性块内属性值的求和
发表于 2003-6-13 20:20:00 | 显示全部楼层 |阅读模式
各位好,我平时在做材料明细表时一般都是用属性块来做,然后导出到excel里求值后再导回cad,最近写了个程序可以直接对属性块内的数量和单重进行求值,但我想求出各个结果后在求总和,但本人由于才疏学浅无法实现这一目的,请各位帮忙给改一下程序,程序代码如下:(另附上一个属性块做的明细表,可以用这个文件进行调试)
Sub cal()
Dim ent As Object
Dim attvar As Variant
Dim ss As AcadSelectionSet
Set ss = GetSelSet
    For Each ent In ss
        If TypeOf ent Is AcadBlockReference Then
            attvar = ent.GetAttributes
        End If
Dim i As Integer
i = 0
    For i = LBound(attvar) To UBound(attvar)
Dim a As Double
Dim b As Double
Dim c As Variant
Dim d As Variant
    a = attvar(3).textString
    b = attvar(4).textString
    c = a * b
    attvar(5).textString = c
        Dim n As Integer
        For n = 0 To ss.Count - 1
        n = n + 1
        d = c
        d = d + d
       Next
       Next
    Next
Dim newtext As AcadText
Dim point1 As Variant
point1 = ThisDrawing.Utility.GetPoint(, "输入总和插入点:")
'attvar(5).textString = c
Set newtext = ThisDrawing.ModelSpace.AddText(d, point1, 3.5)
End Sub
Function GetSelSet() As AcadSelectionSet
    Dim ssName As String
    ssName = "ICKFIRST"
    On Error Resume Next
    Set ss = ThisDrawing.SelectionSets.add(ssName)
    If Err Then
        Set ss = ThisDrawing.SelectionSets(ssName)
        ss.Delete
    End If
    Set ss = ThisDrawing.PickfirstSelectionSet
    If ss.Count = 0 Then
        If Err Then Set ss = ThisDrawing.SelectionSets.add(ssName)
        ss.Clear
        ss.SelectOnScreen
    End If
    Set GetSelSet = ss
End Function
 楼主| 发表于 2003-6-14 17:15:00 | 显示全部楼层
这是图形文件
这是图形文件,期望得到您的帮助
发表于 2003-6-16 20:33:00 | 显示全部楼层
在循环体外定义一个变量保存值即可.
Dim d As Variant,比如这儿定义d保存总重.
For Each ent In ss
        End If
Dim i As Integer
i = 0
Dim a As Double
Dim b As Double
Dim c As Variant
    c = a * b
    d = d + c
    Next
Next
其实变量最好放到循环体外这样可以加快运行速度也可使值不会在下一次循环时被清除.
发表于 2022-4-2 16:41:58 | 显示全部楼层
大侠些,有没有这种现成的求多个相同块中某个数值的和,插入到指定位置?求分享一个,感激不尽。
GMT+8, 2025-4-30 23:22 , Processed in 0.186008 second(s), 24 queries , Gzip On.
