查看: 9520|回复: 11
[事件] tooltip显示图元类型
发表于 2009-6-4 19:10:00 | 显示全部楼层 |阅读模式
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.DatabaseServices;
  3. using Autodesk.AutoCAD.EditorInput;
  4. using Autodesk.AutoCAD.Geometry;
  5. using Autodesk.AutoCAD.Runtime;
  6. namespace tooltip
  7. {
  8.     public class Class1
  9.     {
  10.         Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
  11.         [CommandMethod("TestOn")]
  12.         public void MyTestOn()
  13.         {
  14.             ed.PointMonitor += new PointMonitorEventHandler(ed_PointMonitor);
  15.         }
  16.         [CommandMethod("TestOff")]
  17.         public void MyTestOff()
  18.         {
  19.             ed.PointMonitor -= new PointMonitorEventHandler(ed_PointMonitor);
  20.         }
  21.         void ed_PointMonitor(object sender, PointMonitorEventArgs e)
  22.         {
  23.             Database db = HostApplicationServices.WorkingDatabase;
  24.             InputPointContext ipc = e.Context;
  25.             FullSubentityPath[] ePaths = ipc.GetPickedEntities();
  26.             if (ePaths.Length > 0)
  27.             {
  28.                 FullSubentityPath ePath = ePaths[0];
  29.                 using (Transaction trans = db.TransactionManager.StartTransaction())
  30.                 {
  31.                     ObjectId entId = ePath.GetObjectIds()[0];
  32.                     Entity ent = (Entity)trans.GetObject(entId, OpenMode.ForRead);
  33.                     e.AppendToolTipText("\n这是 :" + ent.GetType().FullName);
  34.                     trans.Commit();
  35.                 }
  36.             }
  37.         }
  38.     }
  39. }
加载DLL,输入teston命令后,用鼠标指向一个图元,会出现tooltip提示。用testoff命令可关掉这个功能。当然,你可以进一步修改代码,如显示扩展数据,加载DLL后功能即打开……
发表于 2019-5-16 16:00:47 | 显示全部楼层
e.AppendToolTipText 不显示内容
发表于 2009-6-4 19:45:00 | 显示全部楼层
以前试过ToolTip,但有个问题,2010里的ToolTip是灰色的底色,
而代码实现的是蓝色的,有办法解决么?
发表于 2009-7-25 22:37:00 | 显示全部楼层
VB代码:
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.GeomeTry
Imports Autodesk.AutoCAD.Runtime
Namespace tooltip
    Public Class Class1
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor        <CommandMethod("TestOn")> _
        Public Sub MyTestOn()
                  AddHandler ed.PointMonitor, New PointMonitorEventHandler(AddressOf ed_PointMonitor)
        End Sub
        <CommandMethod("TestOff")> _
        Public Sub MyTestOff()
            RemoveHandler ed.PointMonitor, New PointMonitorEventHandler(AddressOf ed_PointMonitor)
        End Sub
        Private Sub ed_PointMonitor(ByVal sender As Object, ByVal e As PointMonitorEventArgs)
            Dim db As Database = HostApplicationServices.WorkingDatabase
            Dim ipc As InputPointContext = e.Context
            Dim ePaths() As FullSubentityPath = ipc.GetPickedEntities()
            If ePaths.Length > 0 Then
                Dim ePath As FullSubentityPath = ePaths(0)
                Dim trans As Transaction = db.TransactionManager.StartTransaction()
                Dim entId As ObjectId = ePath.GetObjectIds()(0)
                Dim ent As Entity = CType(trans.GetObject(entId, OpenMode.ForRead), Entity)
                e.AppendToolTipText(vbCrLf & "这是 :" + ent.GetType().FullName)
                trans.Commit()
            End If
        End Sub
    End Class
End Namespace
发表于 2009-7-28 11:42:00 | 显示全部楼层
学习学习
发表于 2009-8-11 19:09:00 | 显示全部楼层
没看懂,希望高手指点一下VBA部分的!
发表于 2011-1-14 20:01:30 | 显示全部楼层
我测试了一下,程序运行正常
可就是看不到ToolTip,不知是什么原因?
发表于 2011-5-3 10:12:59 | 显示全部楼层
好好学习,正是我要学习的东西
发表于 2013-11-6 10:43:49 | 显示全部楼层
我直接使用这个e.AppendToolTipText显示内容,为什么不显示呢?各位大神帮忙啊。。。谢谢了
发表于 2013-11-12 22:40:34 | 显示全部楼层
真不错的工具
发表于 2015-8-8 17:25:33 | 显示全部楼层
学习    了  赞   ~
GMT+8, 2025-5-1 14:32 , Processed in 0.196610 second(s), 28 queries , Gzip On.
