查看: 1874|回复: 6
问了几次了,多段线的长度怎么获得
发表于 2003-6-13 18:46:00 | 显示全部楼层 |阅读模式
问了几次了,多段线的长度怎么获得
劳烦版主回答了几次,
但我运行时却报错呀
贴出我的源程序
Sub Count_len()
    ' 创建新的选择集
    Dim sset As AcadSelectionSet
For i = 0 To ThisDrawing.SelectionSets.Count - 1
ThisDrawing.SelectionSets.Item(i).Clear
ThisDrawing.SelectionSets.Item(i).Delete
Next
On Error Resume Next
    Set sset = ThisDrawing.SelectionSets.Add("SS0")
   sset.SelectOnScreen
     Dim entry As AcadEntity
    Dim l_text As String
    Dim l_l As Double
    Dim Arc_count As Integer
    Dim Line_count As Integer
    For Each entry In sset
        '如果是多段线或曲线的长度,就不行了
        If entry.ObjectName = "AcDbArc" Then
        l_text = l_text & "+" & entry.ArcLength
        l_l = l_l + entry.ArcLength
        Arc_count = Arc_count + 1
        ElseIf entry.ObjectName = "AcDbLine" Then
        l_text = l_text & "+" & entry.Length
        l_l = l_l + entry.Length
        Line_count = Line_count + 1
        End If
    Next entry
ThisDrawing.Utility.Prompt vbCrLf & Arc_count & "个弧," & Line_count & "条直线. 共" & Arc_count + Line_count & "个对象." & vbCrLf & l_text & "=" & l_l & vbCrLf
End Sub
发表于 2003-6-13 22:20:00 | 显示全部楼层
看链接吧
http://www.mjtd.com/function/list.asp?id=308&ordertype=byletter
发表于 2003-6-14 08:03:00 | 显示全部楼层
RE
你用ACAD2004算了。
 楼主| 发表于 2003-6-14 13:32:00 | 显示全部楼层
本程序需要使用VLAX类。什么意思,我不懂
本程序需要使用VLAX类。
什么意思,我不懂
发表于 2003-6-15 09:31:00 | 显示全部楼层
VLAX-VisualLISP ActiveX 模块类
http://www.mjtd.com/mcdown/list.asp?id=85
 楼主| 发表于 2003-6-15 11:15:00 | 显示全部楼层
thanks
多谢版主一直照顾我,
发表于 2012-5-22 15:02:05 | 显示全部楼层
Public Sub Test()  Dim objAcadObject As AcadObject Dim varPickedPoint As Variant Dim objDocument As AcadDocument     ThisDrawing.Utility.GetEntity objAcadObject, varPickedPoint, "請選擇 Polyline"  If TypeOf objAcadObject Is AcadPolyline Then    Dim objPolyline As AcadPolyline    Set objPolyline = objAcadObject    MsgBox "Polyline 長度=" + CStr(objPolyline.Length)  End If  End Sub
GMT+8, 2025-5-29 05:54 , Processed in 0.197142 second(s), 23 queries , Gzip On.
