帖子
查看: 3102|回复: 1
求教:如何让纸张列表与所选择的打印设备同步更新?
发表于 2009-5-28 04:02:00 | 显示全部楼层 |阅读模式
如下图所示,这是我自己做的对话框,其中的打印设备列表已把系统所有的打印设备列出,可随意选择;其下面的纸张列表虽也取得,但无法随打印机的选择同时更新相应的列表,也就是说无法达到CAD系统自带打印对话框的效果。下面的两段程序应该如何关联才能达到此效果?
;;;获取当前所有打印机列表
(defun GetPrinterlist ()
  (vlax-safearray->list
    (vlax-variant-value
      (vla-getplotdevicenames
       (vla-item (vla-get-layouts
                  (vla-get-activedocument (vlax-get-acad-object))
                "Model"
;;;获得纸张类型列表
(defun GetPaperList ()
  (setq    acadobj   (vlax-get-acad-object)
       doc  (vla-get-activedocument acadobj)
       layout      (vla-get-activelayout doc)
  (vla-RefreshPlotDeviceInfo layout)
  (setq    CanPaperSizeVar
        (vla-GetCanonicalMediaNames layout)
       CanPaperSizeArr
        (vlax-variant-value CanPaperSizeVar)
       CanPaperSizeLIst
        (vlax-safearray->list CanPaperSizeArr)
       PaperSize '()
       index 0
  (repeat (length CanPaperSizeList)
    (setq Papersize (cons (vla-GetLocaleMediaName
                         layout
                         (nth index CanPaperSizeList)
                       Papersize
         index       (1+ index)
  (reverse PaperSize)
以下是与对话框相关的操作
  (setq printerlist (getprinterlist))
  (start_list "printer")
  (mapcar 'add_list printerlist)
  (end_list)
  (if (setq paperlist (getpaperlist))
      (start_list "paper")
      (mapcar 'add_list paperlist)
      (end_list)
 楼主| 发表于 2009-5-28 04:07:00 | 显示全部楼层
真郁闷,不会贴图!
GMT+8, 2025-6-6 11:35 , Processed in 0.169084 second(s), 23 queries , Gzip On.
