查看: 2799|回复: 3
[求助]请帮忙看下这个程序,急!急!急!
发表于 2009-5-22 19:35:00 | 显示全部楼层 |阅读模式
目的是选取任意两点计算方位角,代码如下:
Sub calculateangel()
    Dim point1 As Variant
    Dim point2 As Variant
    p1 = ThisDrawing.Utility.GetPoint(, vbCrLf & "第一点:")
    p2 = ThisDrawing.Utility.GetPoint(, vbCrLf & "第二点:")
    Const pi As Single = 3.14
    Dim x As Double
    Dim y As Double
    Dim z As Double
    Dim ang1to2 As Double
    x = point1(0) - point2(0)
    y = point1(1) - point2(1)
    z = point1(2) - point2(2)
    ang1to2 = pi - Sgn(y) * pi / 2 - Atn(y / x)
    MsgBox "两点之间的方位角为:" & ang1to2, , "个计算单位"
End Sub
希望高手尽快给个解答!
 楼主| 发表于 2009-5-24 22:18:00 | 显示全部楼层
为什么没有人帮忙看下这个程序啊 ?
目的就是选取任意两个点计算角度,我不知道哪里出错了。
我是根据计算两点距离而编辑的程序
发表于 2009-5-26 19:49:00 | 显示全部楼层
怎么将point1改为P1,point2改为P2了!!!!
  1. Sub calculateangel()
  2.     Dim point1 As Variant
  3.     Dim point2 As Variant
  4.     point1 = ThisDrawing.Utility.GetPoint(, vbCrLf & "第一点:")
  5.     point2 = ThisDrawing.Utility.GetPoint(point1, vbCrLf & "第二点:")
  6.     Const pi As Single = 3.14
  7.     Dim x As Double
  8.     Dim y As Double
  9.     Dim z As Double
  10.     Dim ang1to2 As Double
  11.     x = point1(0) - point2(0)
  12.     y = point1(1) - point2(1)
  13.     z = point1(2) - point2(2)
  14.     ang1to2 = pi - Sgn(y) * pi / 2 - Atn(y / x)
  15.     MsgBox "两点之间的方位角为:" & ang1to2, , "个计算单位"
  16. End Sub
发表于 2013-6-28 18:09:24 | 显示全部楼层
谢谢3楼分享,学习一下
GMT+8, 2025-5-25 00:15 , Processed in 0.186938 second(s), 23 queries , Gzip On.
