查看: 2348|回复: 12
[求助]麻烦高手帮忙做个填充
发表于 2009-5-21 15:26:00 | 显示全部楼层 |阅读模式
麻烦高手帮忙做个填充,谢谢,样式在附件里面
不好意思,忘记点上传了~~
发表于 2009-5-21 18:24:00 | 显示全部楼层
没有附件啊?
 楼主| 发表于 2009-5-23 01:54:00 | 显示全部楼层
哪位大侠帮帮忙呀?
发表于 2009-5-23 21:56:00 | 显示全部楼层
试试这个? 以前也没做过填充, 有些不理解其中的技巧, 不知道是不是有更简单的定义方式.
旋转角度 45, 就上面的图, 比例为 1
 楼主| 发表于 2009-5-24 03:00:00 | 显示全部楼层
非常感谢蜘蛛大侠!
有没有办法改成0度呀?
*110, YQArch's pattern
134.725859,0.22857143,0.1875,14.2307839,-0.0202994,0.08796846,-18.385407
45.2741403,0.16666667,0.25,4.24259212,-0.0202994,0.08796846,-18.385407
134.725859,0.22857143,0.3125,4.24259212,0.02029948,0.08796846,-18.385407
134.725859,0.14761905,0.1875,14.2307839,-0.0202994,0.08796846,-18.385407
45.2741403,0.08571429,0.25,4.24259212,-0.0202994,0.08796846,-18.385407
134.725859,0.14761905,0.3125,4.24259212,0.02029948,0.08796846,-18.385407
134.725859,0.06190476,0.1875,14.2307839,-0.0202994,0.08796846,-18.385407
45.2741403,0.,0.25,4.24259212,-0.0202994,0.08796846,-18.385407
134.725859,0.06190476,0.3125,4.24259212,0.02029948,0.08796846,-18.385407
0.,0.,0.25,0.,0.375
0.,0.,0.3125,0.,0.375
0.,0.,0.1875,0.,0.375
0.,0.,0.375,0.,0.375
45.2741403,0.16666667,0.125,4.24259212,-0.0202994,0.08796846,-18.385407
134.725859,0.22857143,0.0625,14.2307839,-0.0202994,0.08796846,-18.385407
45.2741403,0.16666667,0.,14.2307839,0.02029948,0.08796846,-18.385407
45.2741403,0.08571429,0.125,4.24259212,-0.0202994,0.08796846,-18.385407
134.725859,0.14761905,0.0625,14.2307839,-0.0202994,0.08796846,-18.385407
45.2741403,0.08571429,0.,14.2307839,0.02029948,0.08796846,-18.385407
45.2741403,0.,0.125,4.24259212,-0.0202994,0.08796846,-18.385407
134.725859,0.06190476,0.0625,14.2307839,-0.0202994,0.08796846,-18.385407
45.2741403,0.,0.,14.2307839,0.02029948,0.08796846,-18.385407
0.,0.,0.125,0.,0.375
0.,0.,0.0625,0.,0.375
这是我找了一个填充制作工具做的,但是里面比例就不知道是多少了,反正不是整数
能不能解释一下这个填充的制作思路?
发表于 2009-5-24 09:29:00 | 显示全部楼层
晕, 自己确实是手潮了. 上面这么简单的定义就能形成目标填充, 我怎么就愣是给整出来那么多行呢?
看了半天, 也下载了个比较推荐的 aHatch Pro 来, 还是没能看明白
唉, 我上面也说过了的, 自己也是刚看的这个, 以前没做过. 自己都没怎么看明白啊.
 楼主| 发表于 2009-5-24 12:57:00 | 显示全部楼层
可以帮我改一下吗?
把你做的那个改成0度角填充的或者把我贴上去的那个改成按在1楼贴的那样
发表于 2009-5-24 18:43:00 | 显示全部楼层
做个填充没有这么难吧!!!
 楼主| 发表于 2009-5-24 20:25:00 | 显示全部楼层
呵呵,那你很有潜力
发表于 2009-5-24 21:43:00 | 显示全部楼层
后看了些时间的你提供的那个填充, 还是没能明白.
将自己的这个显得比较愚笨的, 在 Excel 里转换了下, 贴上来吧. 比例 1, 角度 0. 大致试了下, 可以的.
GMT+8, 2025-5-8 15:43 , Processed in 0.165951 second(s), 26 queries , Gzip On.
