查看: 18291|回复: 14
Inventor Pro 2010 下载地址集合
发表于 2009-4-26 20:37:00 | 显示全部楼层 |阅读模式
Inventor Pro 2010 简体中文版、英文版 X86(32位)下载:
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=75043
Inventor Pro 2010 简体中文版、英文版 X64(64位)下载:
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=75117
Inventor Pro 2010 简体中文版 塑料模具设计模块 下载:
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=75202
Inventor 2010 各不同版本注册方法(与AutoCAD 2010相同):
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=75033
发表于 2009-5-1 10:40:00 | 显示全部楼层
关注中。
发表于 2009-5-2 09:36:00 | 显示全部楼层
轉貼keygen資料
Instruction on how to use the keygen is in the supplied readme.txt file. The supplied Product Key does not work for all versions of 2010 software. Below are the Product keys I found from another forum. I've tested it with Autodesk AutoCAD 2010 and it worked fine.
Good Luck
Serials:
666-69696969
667-98989898
400-45454545
Product Keys:
001B1 - Autodesk AutoCAD 2010
057B1 - AutoCAD LT 2010
128B1 - Autodesk 3ds Max 2010
129B1 - AutoCAD Map 3D 2010
185B1 - AutoCAD Architecture 2010
206B1 - AutoCAD Mechanical
225B1 - Electrical
235B1 - ACE MEP
237B1 - Civil 3D
240B1 - AutoCAD Revit Architecture 2010
241B1 - AutoCAD Revit Architecture Suite 2010
255B1 - AutoCAD Revit Structure 2010
256B1 - AutoCAD Revit Structure Suite 2010
257B1 - AutoCAD Revit MEP Suite 2010
262B1 - Showcase 2010
276B1 - Autodesk MapGuide 2010
279B1 - Direct Connect for JT 2010
294B1 - Inventor Tooling Suite
295B1 - Autodesk Showcase Professional 2010
297B1 - AutoCAD Revit MEP 2010
340B1 - Raster Design 2010
462B1 - AutoCAD Inventor Professional Suite 2010
464B1 - Inventor R-SYS
466B1 - Inventor SIMULATION
467B1 - Autodesk Topobase Web 2010
475B1 - TOPOBASE CLIENT 2010
495B1 - Autodesk 3ds Max Design 2010
504B1 - Navisworks Review
506B1 - Navisworks Simulate
507B1 - Navisworks Manage
527B1 - Inventor Suite 2010
532B1 - DIRECT CONNECT for CATIA 4
544B1 - CIVIL 2010
546B1 - ROBOT STRUCTURAL ANALYSIS 2010
547B1 - ACE-ROBOT STRUCTURAL ANALYSIS PRO 2010
569B1 - Autodesk Vault Manufacturing
586B1 - Showcase Presenter
Code:
http://rapidshare.com/files/223090837/AUTODESK_KEY_2010.rar
The keygen also activates (tested):
552A1 - Autodesk ImageModeler 2009 Service Pack 1
551A1 - Autodesk Stitcher Unlimited 2009 Service Pack 1
590A1 - Autodesk Softimage 7.5 (Standard)
发表于 2009-5-27 13:31:00 | 显示全部楼层
楼主您好!我用Raysource下载,怎么有些链接不上去或网页不存在。g080221@163.com
发表于 2009-6-9 11:46:00 | 显示全部楼层
楼主:AIP2010 32的有3 5 6 9 11,ACM 32的有2 4 6,AIP 64的有1 5 6 7 9 10 11 12 13 14,ACM 64的有2 5 6用没有链接界面或不存在了(我用Raysource下载),这是怎么回事?谢谢!
发表于 2009-7-1 09:57:00 | 显示全部楼层
谢谢楼主,我用讯雷下载速度很快!
发表于 2009-7-27 19:16:00 | 显示全部楼层
Raysource网盘数据已被删除,所以无法链接。
发表于 2009-8-13 11:05:00 | 显示全部楼层
Inventor 我喜欢,只惜用的人太少,太少……
发表于 2009-11-1 22:26:00 | 显示全部楼层
不能下载的到这里看看:
http://www.verycd.com/topics/2745994/
发表于 2009-11-19 22:57:00 | 显示全部楼层
不错。。。。。。
GMT+8, 2025-5-1 08:02 , Processed in 0.439381 second(s), 29 queries , Gzip On.
