查看: 2352|回复: 2
求助解决lisp程序的错误
发表于 2009-4-1 09:41:00 | 显示全部楼层 |阅读模式
求助解决lisp程序的错误
;;;画剖面线
;;;定义默认通用填充图像名称式填充
(defun c:AH ()
(setvar "pickbox" 22)
(setq clay (getvar "clayer")) ; 原始图层状态赋值给oldlay
(setvar "hpname" "ansi31" )
;(VL-CMDF "UNITS" "2""4""1""4""0""n")
;(princ"[设定默认图形单位为_毫米、角度为_0、填充图案为_通用型]")
(initdia)
(VL-CMDF "_.BHATCH" )
(while (/= 0 (getvar "cmdactive")); 没有它回不到原来图层
(SETVAR "CLAYER" CLAY))
(princ))
运行时出现错误如下
*** INTERNAL ERROR: VL namespace mismatch
 type Y to reset: *取消*
; 错误: 函数被取消
发表于 2009-4-18 16:47:00 | 显示全部楼层
  1. ;;;画剖面线
  2. ;;;定义默认通用填充图像名称式填充
  3. (defun c:AH()
  4.    (setq blmch '("cmdecho" "pickbox" "hpname" "clayer")
  5.          bldzh (mapcar 'getvar blmch)
  6.    )
  7.    (mapcar 'setvar blmch (list 0 22 "ansi31" (last bldzh)))
  8.    (if (= (tblsearch "layer" "新图层") nil) ;你需要什么图层名就将"新图层"为你所需的名字即可
  9.        (command "_layer" "n" "新图层" "")
  10.    )
  11.    (setvar "clayer" "新图层")
  12.    (initdia 0)
  13.    (command "_bhatch" (getpoint "\n请选择内部的点:") "")
  14.    (mapcar 'setvar blmch bldzh);恢复以前的值
  15.    (princ)
  16. )
 楼主| 发表于 2009-6-26 13:05:00 | 显示全部楼层
谢谢yshf 帮我解决了这个困惑!
GMT+8, 2025-5-25 05:10 , Processed in 0.143183 second(s), 22 queries , Gzip On.
