查看: 3176|回复: 3
谁能帮我做一个引线标注 的LISP程序
发表于 2009-3-28 13:51:00 | 显示全部楼层 |阅读模式
谁能帮我做一个引线标注 的LISP程序
发表于 2009-3-30 19:29:00 | 显示全部楼层
;引线标注
(defun c:le(/ V1 V2)
              (setvar "cmdecho" 0)(command "undo" "be")
              (princ "引线标注:")
              (setq v1 (getvar "osmode"))
              (setvar "osmode" 515)
;             (setq v2 (getvar "orthomode"))
              (setvar "orthomode" 0)
              (command "dim" "l" pause)
              (setvar "OSMODE" v1)
;             (setvar "orthomode" v2)
              (command "undo" "e")(setvar "cmdecho" 1)
;;;引线标注,直接标注清角符号CA
(defun c:CA (/ v1)
         (setvar "cmdecho" 0)(command "undo" "be")(princ)
         (princ "\引线标注,直接标注清角符号CA")
         (princ "\n请选择标注起点:")
         (command "dim" "l"  pause pause "" "CA" "exit")
发表于 2009-3-30 19:52:00 | 显示全部楼层
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=72509
明经CAD社区 → 工程篇 → 建筑工程 → [原创]引线标注X和Y坐标值的程序
 楼主| 发表于 2009-4-1 10:05:00 | 显示全部楼层
非常谢谢!!!!!!!!!
GMT+8, 2025-5-23 07:54 , Processed in 0.154419 second(s), 23 queries , Gzip On.
