查看: 4656|回复: 4
求过直线端点作垂线
发表于 2009-3-10 22:36:00 | 显示全部楼层 |阅读模式
已知p1-Pa线段长度为5,夹角为10度
用Kp1-pa = deltaY/deltaX
oo-pa线段斜率为Koo-pa = -1/Kp1-pa
alfa = 10 * Atn(1)*4/180
PaX= 5*cos(Alfa) =  4.924039
PaY = 5 * Sin(Alfa) = 0.868241
Kp1-pa= 5.6713
Koo-pa = -1/ Kp1-pa = -0.763
OOy = -PaX * Koo-pa = 28.79385
 楼主| 发表于 2009-3-11 21:59:00 | 显示全部楼层
  1. Sub ls()
  2.   Dim l As AcadLine
  3.   Dim Pp(2) As Double
  4.   Dim Ang, Ang1
  5.   With ThisDrawing
  6.     Set l = .HandleToObject("151")
  7.     With l
  8.       'Debug.Print l.EndPoint(0)
  9.       Kab = .Delta(0) / .Delta(1)
  10.       K0 = -1 / Kab
  11.       y = -.EndPoint(0) / K0 + .Delta(1)
  12.       Ang = -Atn(1) * 2 + 2 * .Angle
  13.       'Debug.Print 90 + Ang * 180 / (Atn(1) * 4)
  14.       Ang1 = -Atn(1) * 2 - 2 * .Angle
  15.       Pp(0) = 0: Pp(1) = y / 2
  16.     End With
  17.     ''
  18.     Dim objArc As AcadArc
  19.     Set objArc = .ModelSpace.AddArc(Pp, y / 2, Ang1, Ang)
  20.
  21.   End With
  22. End Sub
参与人数 1威望 +1 明经币 +1 金钱 +15 贡献 +10 激情 +10 收起 理由
highflybir + 1 + 1 + 15 + 10 + 10 【好评】好程序 欢迎常来此处,谢谢你提
发表于 2009-3-13 10:51:00 | 显示全部楼层
好! 需要这个
发表于 2009-3-13 18:01:00 | 显示全部楼层
To ningyong58:
OOy = 5/sin(10*atn(1)*4/180)
就可以了,不要这么复杂。
发表于 2019-9-14 16:16:20 | 显示全部楼层
哪位能提供个源码
GMT+8, 2025-5-1 02:46 , Processed in 0.193385 second(s), 25 queries , Gzip On.
