查看: 1092|回复: 2
[求助]求助关于方框的坐标的获取问题
发表于 2009-3-1 14:22:00 | 显示全部楼层 |阅读模式
请问使用什么函数可以实现在双击方框的时候获取方框的坐标,我想使用坐标遍历方框内的对象,进行某种输出操作,谢谢。
 楼主| 发表于 2009-3-1 14:25:00 | 显示全部楼层
补充一下,是任意画出来的方框,方框的大小和位置都是不确定的,望不吝赐教~~
发表于 2009-3-1 19:00:00 | 显示全部楼层
Sub Example_Coordinates()
    ' This example creates a polyline. It then uses the Coordinates
    ' property to return all the coordinates  in the polyline. It then
    ' resets one of the vertices using the Coordinates property.
    Dim plineObj As AcadPolyline
    ' Create Polyline
    Dim points(5) As Double
    points(0) = 3: points(1) = 7: points(2) = 0
    points(3) = 9: points(4) = 2: points(5) = 0
    Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
    ThisDrawing.Regen True
    ' Return all the coordinates of the polyline
    Dim retCoord As Variant
    retCoord = plineObj.Coordinates
    ' Display current coordinates for the second vertex
    MsgBox "The current coordinates of the second vertex are: " & points(3) & ", " & points(4) & ", " & points(5), vbInformation, "Coordinates Example"
    ' Modify the coordinate of the second vertex to (5,5,0). Note that in
    ' case of a lightweight Polyline, indices will be different because the points are 2D only.
    points(3) = 5
    points(4) = 5
    points(5) = 0
    plineObj.Coordinates = points
    ' Update display
    MsgBox "The new coordinates have been set to " & points(3) & ", " & points(4) & ", " & points(5), vbInformation, "Coordinates Example"
End Sub
GMT+8, 2025-6-6 22:18 , Processed in 0.171090 second(s), 23 queries , Gzip On.
