查看: 1051|回复: 4
[求助]简单图形程序
发表于 2009-2-14 21:16:00 | 显示全部楼层 |阅读模式
以常要画这些零件,小弟初学lisp程序,写了一个如下
(defun c:ss ()
(setq a1 (getpoint "请输入角点:"))
(setq ll (getdist a1 "\n 请输入长度:"))
(setq ww (getdist a1 "\n 请输入宽度:"))
(setq hh (getdist a1 "\n 请输入高度:"))
(setq a4 (polar a1 0 ll))
(setq d4 (polar a4 (/ pi 2) ww))
(setq d1 (polar d4 pi ll))
(command "rectang" a1 d4 "")
(setq a5 (polar a1 0 (+ ll 80)))
(setq a7 (polar a5 0 hh))
(setq d7 (polar a7 (/ pi 2) ww))
(setq d5 (polar d7 pi hh))
(command "rectang" a5 d7 "")
(setq a2 (polar a1 0 20))
(setq b2 (polar a2 (/ pi 2) (/ (- ww 64) 2)))
(command "circle" b2 5 "")
(setq d2 (polar d1 0 20))
(setq c2 (polar d2 (/ (* 3 pi) 2) (/ (- ww 64) 2)))
(command "circle" c2 5 "")
(setq a3 (polar a4 pi 20))
(setq b3 (polar a3 (/ pi 2) (/ (- ww 64) 2)))
(command "circle" b3 5 "")
(setq d3 (polar d4 pi 20))
(setq c2 (polar d3 (/ (* 3 pi) 2) (/ (- ww 64) 2)))
(setq a6 (polar a5 0 (/ hh 2)))
(setq b6 (polar a6 (/ pi 2) (/ (- ww 64) 2)))
(command "circle" b6 5 "")
(setq d6 (polar d5 0 (/ hh 2)))
(setq c6 (polar d6 (/ (* 3 pi) 2) (/ (- ww 64) 2)))
(command "circle" c6 5 "")
但加载后运行,两个矩形是画出来了,可是孔的位置不对,请各位帮帮忙,问题出在哪里?谢谢!
发表于 2009-2-14 21:59:00 | 显示全部楼层
关闭补捉再试
 楼主| 发表于 2009-2-14 23:04:00 | 显示全部楼层
谢谢,可以了
还想问一下,怎么写关闭捕捉的程序语句
发表于 2009-2-15 09:12:00 | 显示全部楼层
(SetVar "OsMode" 0)
or
(setvar "OSMODE" (boole 7 (getvar "OSMODE") 16384))
 楼主| 发表于 2009-2-15 12:08:00 | 显示全部楼层
搞定了,谢谢各位大虾
GMT+8, 2025-7-29 17:13 , Processed in 0.554451 second(s), 25 queries , Gzip On.
