查看: 2303|回复: 8
[求助]自动修剪
发表于 2009-2-7 09:42:00 | 显示全部楼层 |阅读模式
各位友人:如何实现,自动修剪,只保留矩形内线段!烦请给个例子吧!
发表于 2009-2-8 11:52:00 | 显示全部楼层
顶,顶!
发表于 2009-2-13 17:05:00 | 显示全部楼层
这个简单,不知道你解决了没有,首先选定那个矩形,然后发送截断命令,用栏选,选取四个点比矩形大的四个点,就是再建一个矩形。 Set AcadApp = GetObject(, "AutoCAD.Application")
On Error GoTo ert
  startpnt = AcadApp.ActiveDocument.Utility.GetPoint(, vbCrLf + "正在准备标注点" & j & "请输入点位:")
insertionpnt1(0) = startpnt(0) - 0.5: insertionpnt1(1) = startpnt(1) - 0.5: insertionpnt1(2) = startpnt(2):
Set obj_Text1 = AcadApp.ActiveDocument.ModelSpace.AddText(j, insertionpnt1, 1)
Set cice = AcadApp.ActiveDocument.ModelSpace.AddCircle(startpnt, rad)
Dim ae As AcadObject
ad = cice.Handle
Dim at As String
Set ab = AcadApp.ActiveDocument.ModelSpace.AddCircle(startpnt, rad)
point1(0) = startpnt(0): point1(1) = startpnt(1) - 1: point1(2) = startpnt(2)
point2(0) = startpnt(0) - 1: point2(1) = startpnt(1): point2(2) = startpnt(2)
point3(0) = startpnt(0): point3(1) = startpnt(1) + 1: point3(2) = startpnt(2)
point4(0) = startpnt(0) + 1: point4(1) = startpnt(1): point4(2) = startpnt(2)
Text1 = point1(0) & "," & point1(1)
Text2 = point2(0) & "," & point2(1)
Text3 = point3(0) & "," & point3(1)
Text4 = point4(0) & "," & point4(1)
Set ae = AcadApp.ActiveDocument.HandleToObject(ad)
at = "(handent " & Chr(34) & ad & Chr(34) & ")"
AcadApp.ActiveDocument.SendCommand "_trim" & vbCr & at & vbCr & vbCr & "f" & vbCr & Text1.Text & vbCr & Text2.Text & vbCr & Text3.Text & vbCr & Text4.Text & vbCr & vbCr & vbCr
我这个截取圆内的线段,你只需要把坐标改成比矩形大的坐标就行了,完全可以做到,我应用过的。
发表于 2009-2-13 21:42:00 | 显示全部楼层
这个就是专门为你写的完整代码:运行时先选择一个矩形,右键即可完成你要的操作
Sub tttt()
   Dim p As Variant
   Dim ent As AcadEntity
   Dim min, max As Variant
   Dim a(0 To 2) As Double
   Dim b(0 To 2) As Double
   ThisDrawing.Utility.GetEntity ent, p, "请选择一个矩形:"
   ent.GetBoundingBox min, max
   st3 min, min(0) - 0.001, min(1) - 0.001, 0
   st3 max, max(0) + 0.001, max(1) + 0.001, 0
   st3 a, min(0) - 0.001, max(1) + 0.001, 0
   st3 b, max(0) + 0.001, min(1) - 0.001, 0
   ThisDrawing.SendCommand "_trim" & vbCr & "(handent """ & ent.Handle & """)" & vbCr & vbCr & "f" & vbCr & min(0) & "," & min(1) & vbCr & a(0) & "," & a(1) & vbCr & max(0) & "," & max(1) & vbCr & b(0) & "," & b(1) & vbCr & min(0) & "," & min(1) & vbCr & vbCr & vbCr
End Sub
发表于 2009-2-14 10:59:00 | 显示全部楼层
判断选择实体的四个相交点,用BREAK截断,在把角点在该对象之外的所有线条DEL就OK了,这样更方便一些
发表于 2009-4-13 19:59:00 | 显示全部楼层
四楼主代码中的st3是指什么啊????????????
发表于 2009-4-13 20:06:00 | 显示全部楼层
假如相反,我只保留矩形外的线段,删除矩形里的线段该怎么做啊??????????
发表于 2009-4-13 20:13:00 | 显示全部楼层
希望nhy12345678给予回答啊!!!!!!!!!!!
发表于 2009-4-18 10:27:00 | 显示全部楼层
希望楼主能够及时回复,这个方法有个问题,当矩形斜过来的时候好像就不起作用了!!!!!!!!!!!!!!!!!!!!!!!
GMT+8, 2025-6-6 20:56 , Processed in 0.176455 second(s), 24 queries , Gzip On.
