查看: 1277|回复: 2
[求助]■ 属性块数值刷为何失效
发表于 2009-1-20 23:18:00 | 显示全部楼层 |阅读模式
关于属性块的 我自己根据网上的帖子 编了个程序:提取一个属性块A中的值去刷另一个属性块B 可以刷 我将属性块A复制出属性块A1 再用A1刷B 也没问题 但当再用A去刷B时就不管用了 不知道是怎么回事 请教下大家
源码如下:
  1. (defun c:BFB (/ zqm ename pipe_number elist line_size ssa n index 1st txt txt1)
  2.   (setq zqm nil)
  3.   (while (= zqm nil)
  4.     (setq zqm (entsel "\n选择管道标注: "))
  5.     (if zqm
  6.       (if (and
  7.     (/= "INSERT" (cdr (assoc 0 (entget (car zqm)))))
  8.     (/= "LINE_NUMBER" (cdr (assoc 2 (entget (car zqm)))))
  9.   )
  10. (setq zqm nil)
  11.       )
  12.     )
  13.   )
  14.   (setq ename (entnext (car zqm)))
  15.   (while ename
  16.     (setq elist (entget ename))
  17.     (if (and
  18.   (= (cdr (assoc 0 elist)) "ATTRIB")
  19.   (= (cdr (assoc 2 elist)) "PIPE_NO")
  20. )
  21.       (setq Pipe_number (cdr (assoc 1 elist)))
  22.     )
  23.     (if (and
  24.   (= (cdr (assoc 0 elist)) "ATTRIB")
  25.   (= (cdr (assoc 2 elist)) "SIZE")
  26. )
  27.       (setq line_size (cdr (assoc 1 elist)))
  28.     )
  29.     (setq ename (entnext ename))
  30.   )
  31.   (setq ssa (ssget (list (cons 0 "INSERT") (cons 2 "VALVE"))))
  32.   (setq n (sslength ssa))
  33.   (setq index (- n 1))
  34.   (repeat n
  35.     (setq ename (ssname ssa index))
  36.     (setq a (entnext ename))
  37.     (while a
  38.       (setq lst (entget a))
  39.       (if (= "LINE_NUMBER" (cdr (assoc 2 lst)))
  40. (progn
  41.   (setq txt (cdr (assoc 1 lst)))
  42.   (setq txt1 (cons 1 Pipe_number))
  43.   (setq lst (subst
  44.       txt1
  45.       (assoc 1 lst)
  46.       lst
  47.     )
  48.   )
  49.   (entmod lst)
  50. )
  51.       )
  52.       (if (= "VALVE_SIZE" (cdr (assoc 2 lst)))
  53. (progn
  54.   (setq txt (cdr (assoc 1 lst)))
  55.   (setq txt1 (cons 1 line_size))
  56.   (setq lst (subst
  57.       txt1
  58.       (assoc 1 lst)
  59.       lst
  60.     )
  61.   )
  62.   (entmod lst)
  63. )
  64.       )
  65.       (if (= (cdr (assoc 1 lst)) "SEQEND")
  66. (setq a nil)
  67.       )
  68.       (setq a (entnext a))
  69.     )
  70.     (entupd ename)
  71.     (setq index (1- index))
  72.   )
  73.   (princ)
  74. )
 楼主| 发表于 2009-1-20 23:19:00 | 显示全部楼层
 楼主| 发表于 2009-1-21 01:09:00 | 显示全部楼层
问题已解决 谢谢大家!
GMT+8, 2025-7-29 17:11 , Processed in 0.182779 second(s), 27 queries , Gzip On.
