查看: 1410|回复: 2
[讨论]AddLightWeightPolyline无效
发表于 2009-1-14 08:38:00 | 显示全部楼层 |阅读模式
实时错误 '-2145320943 (80210011)':
Too few elements in SafeArray or total number of elements is not a multiple of three
以下代码开始运行的好好的,不知何时突然不行了!
Dim PL(10) As Double
    PL(0) = 0
    PL(1) = 0
    PL(2) = 0
    PL(3) = 300
    PL(4) = 300
    PL(5) = 300
    PL(6) = 300
    PL(7) = 0
    PL(8) = 0
    PL(9) = 0
Set P = acaddoc.ModelSpace.AddLightWeightPolyline(PL)
发表于 2009-1-14 13:11:00 | 显示全部楼层
Sub  AddLightWeightPolyline()
    ' This example creates a lightweight polyline in model space.
    Dim plineObj As AcadLWPolyline
    Dim points(0 To 9) As Double
    ' Define the 2D polyline points
    points(0) = 0: points(1) = 0
    points(2) = 0: points(3) = 300
    points(4) = 300: points(5) = 300
    points(6) = 300: points(7) = 0
    points(8) = 0: points(9) = 0
    ' Create a lightweight Polyline object in model space
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
End Sub
试试看
 楼主| 发表于 2009-1-14 16:42:00 | 显示全部楼层
感谢,楼上!
错误原因找到了!
GMT+8, 2025-6-6 22:46 , Processed in 0.183296 second(s), 24 queries , Gzip On.
