查看: 1099|回复: 2
求助,帮忙看一段程序,是什么意思
发表于 2009-1-6 20:28:00 | 显示全部楼层 |阅读模式
(COMMAND "layer" "n"
       "xsx"   "c"
       "green" "xsx"
"n“  "xx"
       "c"
       "yellow"   "xx"   "l"
       "dashed  "xx "n"
       "dhx"   "c"
       "cyan"  "dhx"   "l"
 "center"dhx"   "n"
       "csx"   "s"  "xsx"
这段程序中的那么多""是什么意思啊!
我想做四个图层  层名分别为,lay1 lay2 lay3 lay4
           颜色是  7   1   2   3
     线形是    continous  center   dashed   continous
    线宽是  0.5  和  三个缺省
这个图层怎么编啊,求助了,谢谢了,我是初学者,没有什么学习资料,哪位高人要是会,就麻烦了!谢谢!
发表于 2009-1-7 09:02:00 | 显示全部楼层
(command "layer" "m" "lay1" "c" "7" "" "l" "continous"  "" "lw" "0.5"  ""
          "m" "lay2" "c" "1" "" "l" "center"  "" "lw" 0.5 ""
          "m" "lay3" "c" "2" "" "l" "dashed" ""  "lw" 0.5 ""
           "m" "lay4" "c" "3" "" "l" "continous" "" "lw" 0.5 "")
发表于 2009-1-7 11:00:00 | 显示全部楼层
在lisp中,一对""或(command)都等同于按了空格或回车
在lisp中如不知道调用的acad命令如何操作,可以在命令行提示下输入命令,以便更好的写lisp
上述lisp你还是不明白的话,按照lisp的内容一一在命令行内输入就知道该行究竟搞什么东西了
GMT+8, 2025-7-29 17:36 , Processed in 0.268652 second(s), 27 queries , Gzip On.
