我也曾经疑惑过很长时间。看看下面代码吧:vbnet的,自己转下。 <CommandMethod("testcut")> _ Public Sub cut() Dim db As Database = HostApplicationServices.WorkingDatabase Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor Dim ts As String = vbCr & "请选择线条(圆弧、直线或者多义线):" Dim opt As New PromptEntityOptions(ts) opt.SetRejectMessage(vbCr & "只能线条") opt.AddAllowedClass(GetType(Polyline), True) opt.AddAllowedClass(GetType(Arc), True) opt.AddAllowedClass(GetType(Line), True) Dim res As PromptEntityResult = ed.GetEntity(opt) If res.Status <> PromptStatus.OK Then ed.WriteMessage("用户自行退出!" & vbCr) Else '获取等分数 Dim iop As New PromptIntegerOptions("指定等分段的数量:") iop.DefaultValue = 10 Dim irt As PromptIntegerResult = ed.GetInteger(iop) Dim n As Integer If irt.Status <> PromptStatus.OK orElse irt.Value < 2 Then Return Else n = irt.Value End If Dim entid As ObjectId = res.ObjectId Using trans As Transaction = db.TransactionManager.StartTransaction() '得到拾取的对象 Dim ent As Entity = trans.GetObject(entid, OpenMode.ForRead) Dim cv As Curve = DirectCast(trans.GetObject(ent.ObjectId, OpenMode.ForWrite), Curve) Dim len As Double = cv.GetDistanceAtParameter(cv.EndParam) Dim i As Integer For i = 0 To n Dim p As Point3d = cv.GetPointAtDist(i * len / n) Dim kp As Object = cv.GetFirstDerivative(cv.GetParameterAtDistance(i * len / n)) Dim ka As Double = kp(1) / kp(0) - Math.PI / 2 Call AddText(p, "等分点" & CStr(i), 3, ka, 1, 1) Next trans.Commit() End Using End If End Sub ' 由插入点、文字内容、文字高度和倾斜角度创建单行文字的函数. ublic Function AddText(ByVal position As Point3d, ByVal textString As String, ByVal height As Double, ByVal rotate As Double, ByVal dq As Integer, ByVal co As Integer) As ObjectId 'position为文字位置,textstring为文字内容,height为文字高度,rotate为文字角度,dq为对齐方式,co为颜色 Try Dim ent As New DBText() ent.Position = position ent.TextString = textString ent.Height = height ent.Rotation = rotate ent.ColorIndex = co Select Case dq Case 0 ent.HorizontalMode = TextHorizontalMode.TextMid Case 1 ent.HorizontalMode = TextHorizontalMode.TextLeft ent.VerticalMode = TextVerticalMode.TextVerticalMid End Select ent.AlignmentPoint = position Dim entId As ObjectId = AppendEntity(ent) Return entId Catch ' 创建失败,则返回一个空的ObjectId. Dim nullId As ObjectId = ObjectId.Null Return nullId End Try End Function ' 将图形对象加入到模型空间的函数. ublic Function AppendEntity(ByVal ent As Entity) As ObjectId Dim db As Database = HostApplicationServices.WorkingDatabase Dim entId As ObjectId Using trans As Transaction = db.TransactionManager.StartTransaction Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForRead) Dim btr As BlockTableRecord = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite) entId = btr.AppendEntity(ent) trans.AddNewlyCreatedDBObject(ent, True) trans.Commit() End Using Return entId End Function
