请大家帮忙,看一下这个程序怎么用不了?急用,可就是运行不了.
(defun c:tt(/ oldorth oldosmo oldcmd pt ss) (setq oldorth(getvar "orthomode") oldosmo(getvar "osmode") oldcmd (getvar "cmdecho")) (setvar "Orthomode" 0) (setvar "osmode" 33) (setvar "cmdecho" 0) (setq pt(getpoint "\n Selection start point:")) (command "pline" pt) (while (command "_circle" pt 2) (setq ss(entget)) (setvar "osmode" 32) ;设置为交点捕捉,求圆与直线的交点 (setq pt(getpoint pt "\n Selection point:")) (command "_erase" ss "") (command pt) ) (command "") (setvar "orthomde" oldorth) (setvar "osmode" oldosmo) (setvar "cmdecho" oldcmd) (print))
我的程序意图是:按指定长段多段线来放线,因为无法控制直线长度,所以只能用相应长度的半径的园来求交点,点取画后多段线.
如附件图中,兰色的线是我要的目的线,长为L,与白色的线相交,我做程序的想法是用圆去与白色的线相交,再画兰色的线.
按照楼主的意思
应该是while的判断式
但是它总是返回nil
所以程序无法执行while循环
本版积分规则 发表回复 回帖后跳转到最后一页
GMT+8, 2025-7-29 17:39 , Processed in 0.143481 second(s), 26 queries , Gzip On.
