楼主: userzhl
[求助]求助caoyin 版主,如何获取QLEADER末端的那个端点的坐标?
 楼主| 发表于 2008-12-22 11:57:00 | 显示全部楼层
(setq ssi (ssget))
(if ssi
(if (= (cdr (assoc 2 (setq edat (entget (setq e (ssname ssi n_in)))))) "材料")
(setq n_in 0)
(setq len_in (sslength ssi))
(command "undo" "begin")
(repeat len_in
    (setq INS (cdr (assoc 10 edat))
 INSc (cdr (assoc 41 edat)))
 (command "_SCALE" e "" INS (/ scal (abs INSc))))
(setq n_in (+ 1 n_in))
(command "undo" "end")
为何会出错呢?
选择对象: 指定对角点: 找到 8 个
选择对象:  ; 错误: 参数类型错误: numberp: nil
发表于 2008-12-22 12:51:00 | 显示全部楼层
(setq ssi (ssget))
(if ssi
(repeat (setq n_in (sslength ssi))
  (if (= (cdr (assoc 2 (setq edat (entget (setq e (ssname ssi (setq n_in (1- n_in)))))))) "材料")
      (command "_SCALE" e "" "_non" INS (/ scal (abs INSc))))
;;我改了一下,但你未指定 scal 变量
GMT+8, 2025-7-30 11:27 , Processed in 0.149673 second(s), 18 queries , Gzip On.
