查看: 1472|回复: 3
求哪个高手知道自动插入菜单的命令?
发表于 2008-12-17 21:55:00 | 显示全部楼层 |阅读模式
现在的情况是,用了
(defun C:AY(/ Menufilename i)
    (setvar "cmdecho" 0)
    (if (null (menugroup "ayunger"));AutoCAD中未加载给菜单组.
            (setq Menufilename (findfile "ayunger.mnu"));Search from autocad setup folder.
            (if (null Menufilename)
                (setq Menufilename (getfiled "打开AYUNGER菜单文件" "Ayunger.mnu" "mnu" 4))
            );end_if
            (if (null Menufilename) (exit));open dialog is ""Cancle" press.
            (setq i 1)
            (while (< i 24)
                (if (menucmd (strcat "P" (itoa i) ".1=?"))
                    (setq i (+ i 1));then
                    (progn;else
                        (vl-cmdf "_menuload" Menufilename)
                        (menucmd (strcat "P" (itoa i) "=+Ayunger.POP1"))
                        (princ "\n◎ 工具菜单已加载,欢迎您使用。邮箱:AyungerStudio@163.com QQ:420304230")
                        (setq i 25)
          );end_progn
                );end_if
            );end_while i
        );end_progn
    );end_if
    (prin1)
);end_defun
这段函数,好像只能实现把菜单加入menuload命令里面那个地方,不能真正实现插入下拉菜单,还得手动选择一下才行,哪个高手知道怎么写能把菜单自动插入进去而不用menuload来设置呢?
发表于 2008-12-17 22:35:00 | 显示全部楼层
 楼主| 发表于 2008-12-18 08:24:00 | 显示全部楼层
难道没有自动选择插入位置的函数么?
发表于 2008-12-18 09:28:00 | 显示全部楼层
请先加载给菜单组,再调试....
GMT+8, 2025-7-30 05:59 , Processed in 0.157363 second(s), 26 queries , Gzip On.
