查看: 34833|回复: 64
★★★【增强框选圆角】★★★
发表于 2008-12-17 11:27:00 | 显示全部楼层 |阅读模式
;;也发一个全功能的框选圆角程序
;;对十字交叉的线可感知圆角方向
;;部分代码参考了网上的程序
(defun c:yad_fillet(/ yad-dxf yad-entsel yad-movetotop yad-interpt goto_fillet oldpedit oldos acaddoc mspace trm p1 p2 prom lprom r boxlen ss l_bak l_pt ent i)
  (defun yad-dxf(en val) (cdr (assoc val (entget en))))
  (defun yad-entsel(msg filter / ext ent pt s)
    (while (not ext)
      (setq ent (entsel msg))
      (cond
        ((= (getvar "errno") 52) (setq ext T) (setvar "errno" 0) nil)
        ((and ent (setq s (ssget "_c" (polar (setq pt (cadr ent)) (* pi 1.25) boxlen) (polar pt (/ pi 4) boxlen) filter)) (setq ext T)) (list (ssname s 0) pt))
        (T (prompt "\n圆角需要直线、圆弧、圆或多段线!"))
  (defun yad-movetotop(l_ent / extdic tbl)
    (setq l_ent (mapcar 'vlax-ename->vla-object l_ent))
    (setq extdic (vla-getextensiondictionary mspace))
    (if (vl-catch-all-error-p (setq tbl (vl-catch-all-apply 'vla-item (list extdic "acad_sortents"))))
      (setq tbl (vla-addobject extdic "acad_sortents" "acdbsortentstable"))
    (vlax-invoke tbl "MoveToTop" l_ent)
  (defun yad-interpt(obj s / n ent ipt pt l_p)
    (setq obj (vlax-ename->vla-object obj) n -1)
    (repeat (sslength s)
      (setq ent (vlax-ename->vla-object (ssname s (setq n (1+ n)))) ipt (vlax-variant-value (vla-intersectwith obj ent 0)))
      (if (and (> (vlax-safearray-get-u-bound ipt 1) 0) (setq ipt (vlax-safearray->list ipt)))
        (while (> (length ipt) 0)
          (setq pt (list (car ipt) (cadr ipt) (caddr ipt)) ipt (cdddr ipt))
          (if (not (vl-member-if '(lambda(e) (equal e pt boxlen)) l_p)) (setq l_p (cons pt l_p)))
    (vla-delete obj)
    l_p
  (defun goto_fillet(p1 p2 / ent1 ent2 wid ent2ispl s oldent newent)
    (setq ent1 (car p1))
    (if (not p2) (redraw ent1 3))
    (if (or p2 (setq p2 (yad-entsel "\n选择第二个对象:" '((0 . "LINE,XLINE,RAY,LWPOLYLINE,SPLINE,ARC,CIRCLE,ELLIPSE")))))
      (if (and (setq ent2 (car p2)) (member "LWPOLYLINE" (mapcar '(lambda(e) (yad-dxf e 0)) (list ent1 ent2))))
          (redraw ent1 4)
          (if (= (yad-dxf ent2 0) "LWPOLYLINE")
            (setq ent1 p2 p2 (cadr p1) ent2 (car p1) p1 (cadr ent1) ent1 (car ent1))
            (setq p1 (cadr p1) p2 (cadr p2))
          (setq wid (yad-dxf ent1 40) ent2ispl (= (yad-dxf ent2 0) "LWPOLYLINE"))
          (if (= trm 0)
              (vla-copy (vlax-ename->vla-object ent1))
              (if (and ent2ispl (not (equal ent1 ent2))) (vla-copy (vlax-ename->vla-object ent2)))
              (yad-movetotop (if (equal ent1 ent2) (list ent1) (list ent1 ent2)))
            (vl-cmdf "_.undo" "_m")
          (setvar "qaflags" 1)
          (if ent2ispl (vl-cmdf "_.explode" ent1 ent2 "") (vl-cmdf "_.explode" ent1 ""))
          (setq s (ssget "_p") oldent (entlast))
          (setvar "qaflags" 0)
          (vl-catch-all-apply 'vl-cmdf (list "_.fillet" (setq ent1 (nentselp p1)) (setq ent2 (nentselp p2))))
          (cond
            ((= trm 0))
            ((and (equal (setq newent (entlast)) oldent) (/= (getvar "filletrad") 0)) (vl-cmdf "_.undo" "_b"))
            (T (vl-catch-all-apply 'vl-cmdf (append (list "_.pedit" (car ent1) "_j")
                                                    (if (equal newent oldent) nil (list newent))
                                                    (if (= (yad-dxf (setq ent2 (car ent2)) 0) "CIRCLE") nil (list ent2))
                                                    (list s "" "_w" wid "")))
          (vl-cmdf "_.erase" s "")
        (vl-catch-all-apply 'vl-cmdf (list "_.fillet" p1 p2))
      (redraw ent1 4)
  (vl-load-com)
  (setq oldpedit (getvar "peditaccept") oldos (getvar "osmode")
        mspace (vla-get-modelspace (setq acaddoc (vla-get-activedocument (vlax-get-acad-object))))
  (setvar "peditaccept" 1)
  (setvar "osmode" 0)
  (setvar "cmdecho" 0)
  (setvar "errno" 0)
  (vl-cmdf "_.undo" "_c" "_n" "_.undo" "")
  (while (/= (getvar "errno") 52)
    (princ "\n当前设置:模式 = ")
    (princ (if (= (setq trm (getvar "trimmode")) 1) "修剪" "不修剪"))
    (princ ",半径 = ")
    (princ (getvar "filletrad"))
    (initget (if (= trm 1) "U N" "U T"))
    (setq p1 (entsel (strcat "\n" (setq prom (strcat "选择对象或指定圆角半径或[放弃(U)/" (if (= trm 1) "不修剪对象(N)" "修剪对象(T)")"]:")))))
    (princ "\n")
    (setq lprom (getvar "lastprompt") r (substr lprom (1+ (vl-string-mismatch prom lprom)))
          boxlen (abs (/ (* (/ (getvar "pickbox") (cadr (getvar "screensize"))) (getvar "viewsize")) (sin (/ pi 4))))
    (if (numberp (setq r (read r)))
      (setvar "filletrad" (abs r))
      (cond
        ((= p1 "U") (vl-cmdf "_.u"))
        ((= p1 "T") (setvar "trimmode" 1))
        ((= p1 "N") (setvar "trimmode" 0))
        ((and (not p1) (/= (getvar "errno") 52) (setq p2 (getcorner (setq p1 (cadr (grread T 6 2))) "\n指定对角点:")))
          (vla-startundomark acaddoc)
          (setq ss nil l_bak nil l_pt nil)
          (cond
            ((and (setq ss (ssget "_f" (list p1 p2) '((0 . "LINE,XLINE,RAY,LWPOLYLINE,SPLINE,ARC,CIRCLE,ELLIPSE"))))
                  (vla-addline mspace (vlax-3d-point p1) (vlax-3d-point p2))
                  (setq l_bak (list ss (setq l_pt (yad-interpt (entlast) ss))))
                  (> (sslength ss) 1) (> (length l_pt) 1)
            ((and (setq ss (ssget "_f" (list p1 (list (car p1) (cadr p2)) p2 (list (car p2) (cadr p1)) p1) '((0 . "LINE,XLINE,RAY,LWPOLYLINE,SPLINE,ARC,CIRCLE,ELLIPSE"))))
                  (vl-cmdf "_.rectang" "_f" 0 p1 p2)
          (if (and l_bak (or (< (length l_pt) 2) (and (= (sslength ss) 1) (> (length (cadr l_bak)) 1)))) (setq ss (car l_bak) l_pt (cadr l_bak)))
          (cond
            ((not ss)
              (princ "\n没有交叉框选到直线、圆弧、圆、椭圆、多段线或样条曲线!")
            ((or (= (sslength ss) 1) (= (length l_pt) 1))
              (goto_fillet (list (setq ent (ssname ss 0)) (car l_pt)) (if (and (= (yad-dxf ent 0) "LWPOLYLINE") (> (length l_pt) 1)) (list ent (cadr l_pt)) nil))
            (T
              (setq p1 (nentselp (car l_pt)) l_pt (cdr l_pt) i -1)
              (while (and (setq p2 (nth (setq i (1+ i)) l_pt)) (setq p2 (nentselp p2)) (equal (car p2) (car p1))))
              (goto_fillet p1 p2)
          (vla-endundomark acaddoc)
        ((and p1 (= (type (setq ent (car p1))) 'ename))
          (if (wcmatch (yad-dxf ent 0) "LINE,XLINE,RAY,LWPOLYLINE,SPLINE,ARC,CIRCLE,ELLIPSE")
            (goto_fillet p1 nil)
            (princ "\n圆角需要直线、圆弧、圆、椭圆、多段线或样条曲线!")
  (setvar "peditaccept" oldpedit)
  (setvar "osmode" oldos)
(princ "\n框选圆角命令:yad_fillet")
参与人数 2威望 +1 明经币 +3 金钱 +20 贡献 +5 激情 +5 收起 理由
linheyuanpcb + 1
mccad + 1 + 2 + 20 + 5 + 5 【精华】好程序
发表于 2019-12-22 14:12:37 | 显示全部楼层
好程序顶一下,楼主能改一下吗,框选的时候好不好实现预览功能啊,试用了一下,判断错误率太高了,除非点选可以,框选每次都很难把握规律,如果鼠标动就能暗线或者虚线显示裁剪下去的内容,到自己想要的位置的时候鼠标再点一下就确认,那样就会方便多了,现在的判断规律我试了很多回 也没发现啥规律。
楼主能看到回帖的话给弄一下吧,如果鼠标移动就能提前看到效果,就基本不错了。能看到,就再弄弄呗,毕竟太久的经典代码了
发表于 2022-6-20 17:56:52 | 显示全部楼层
有点不懂?命令是什么的?yad_fillet  是这个吗?那我自己可以改简单点吧。
发表于 2023-7-11 08:34:55 | 显示全部楼层
感谢楼主,是不是只能选两条线?如果可以多选的话,更好用
发表于 2008-12-17 12:28:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-12-17 12:41:00 | 显示全部楼层
顶一下,不支持相交的spline嘛
发表于 2008-12-17 12:47:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2008-12-17 13:56:00 | 显示全部楼层
caoyin发表于2008-12-17 12:41:00顶一下,不支持相交的spline嘛
漏了,已补上!
发表于 2008-12-17 14:03:00 | 显示全部楼层
非常值得学习一下.
发表于 2008-12-17 14:09:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2008-12-17 15:44:00 | 显示全部楼层
liminnet发表于2008-12-17 14:09:00还是不支持SPLINE呢,老大
不好意思,这回真的补上了!
发表于 2008-12-17 15:58:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-12-17 16:34:00 | 显示全部楼层
支持好东西!如LS所说多样线的倒角存在BUG!
GMT+8, 2025-5-1 15:47 , Processed in 0.559488 second(s), 30 queries , Gzip On.
