查看: 2610|回复: 2
关于地形测量,划分面积的,高手进来看看!急急急!
发表于 2008-12-16 16:48:00 | 显示全部楼层 |阅读模式
已知图形ABCDE相邻点距离和各点坐标值,求点G的坐标,使图形ABCDEG的面积等于100。
这只是画的一个示意图,具体要求是将地块按面积分成5份,这只是其中一份。
各位高手有没有什么好方法???
急!!!
现在的实际情况是如下图所示:要从红线的蓝点处拉一条线到左边红线处,使拉的这条线的上半部分的面积为给出的一个已知面积。在如下图所给出的条件下能确定那个点吗?1-27为各个点的编号,块内的数据为那一块的面积,线旁边的数据为那一条线段的长度,单位为米,比例为1:300
发表于 2022-6-22 17:56:40 | 显示全部楼层
(vl-load-com)
(defun ebox (e / pa pb)
         (Vlax-Invoke-Method (Vlax-Ename->Vla-Object e ) 'GetBoundingBox 'pa 'pb )
             (setq pa (trans (vlax-safearray->list pa) 0 1)
                   pb (trans (vlax-safearray->list pb) 0 1)
             (list pa pb)
(defun cbox (e / box)
         (setq box (ebox e))
         (mid (car box) (cadr box))
(defun mid (p1 p2) (mapcar '* '(0.5 0.5 0.5) (mapcar '+ p1 p2)))
(defun mktext (str pt th)
  (entmake (list '(0 . "TEXT")
                 (cons 1 str)
                 (cons 10 pt)
                 (cons 40 th)
                 (cons 11 pt)
                 (cons 71 0)
                 (cons 72 1)
                 (cons 73 2)
(defun str2lst ( str del / pos )
    (if (setq pos (vl-string-search del str))
        (cons (substr str 1 pos) (str2lst (substr str (+ pos 1 (strlen del))) del))
        (list str)
(defun ptscen (Pts / )
  (MAT:vxs (apply 'mapcar (cons '+ pts)) (/ 1.0 (length pts)))
(defun MAT:vxs ( v s )
  (mapcar (function (lambda ( n ) (* n s))) v)
(defun dxf (key ename) (cdr (assoc key (entget ename))))
(defun 2epi ( e1 e2 mode / l r )
    (setq obj1 (vlax-ename->vla-object e1)
            obj2 (vlax-ename->vla-object e2)
            l (vlax-invoke obj1 'intersectwith obj2 mode))
    (repeat (/ (length l) 3)
        (setq r (cons (list (car l) (cadr l) (caddr l)) r)
              l (cdddr l)
    (reverse r)
(defun p2ld (pt p1 p2 / )
  (car (trans (mapcar '- pt p1) 0 (mapcar '- p2 p1)))
(defun gvp (e)
        (vl-remove nil (mapcar '(lambda (x) (if (= (car x) 10) (trans (cdr x) 0 1))) (entget e)))
(defun mkline (pt1 pt2) (entmakex (list '(0 . "LINE") (cons 10 pt1) (cons 11 pt2))))
(defun new_ss (lastobj / ss obj)
  (setq ss (ssadd))
        (setq obj (entnext lastobj))
        (while obj
            (setq ss (ssadd obj ss))
            (setq obj (entnext obj))
ss
(defun ss2lst ( ss / i l )
    (if ss
        (repeat (setq i (sslength ss))
            (setq l (cons (ssname ss (setq i (1- i))) l))
(defun c:tt ( / a angint ar ar1 bang box cont dd dh dx e e0 ee h h1 lm lstr0 m1 n odlst p1 p2 pa pb pc pm pm1 pts ssn str tm w x)
(vl-load-com)
(setq odlst (mapcar 'getvar '("cmdecho" "osmode")))
(mapcar 'setvar '("cmdecho" "osmode") '(0 0))
(setq cont T)
  (while cont
    (setq str (getstring "\n输入面积划分表<800.22,200,330.45...>"))
    (if (/= str "")(setq cont nil))
        (setq lstr0 (mapcar 'atof (str2lst str ","))
                n (apply '+ lstr0)
                e (car (entsel "\n选择多段线:"))
                p1 (getpoint "\n地块划分起点:")
                p2 (getpoint p1 "\n划分方向:")
                bang (angle p1 p2)
                pc (ptscen (gvp e))
                ar (Vlax-Get (Vlax-Ename->Vla-Object e) 'Area )
                lstr0 (mapcar '(lambda(x) (* x (/ ar n))) lstr0)
                lstr0 (reverse (cdr (reverse lstr0)))
                angint (atof (angtos bang 0 4))
                lm nil
                ee (entlast)
        (vl-cmdf "_.rotate" e "" pc (- 90. angint))
        (setq box (ebox e)
                p1 (car box)
                p2 (cadr box)
(mapcar 'set '(w h) (mapcar '- p2 p1))
(vla-copy (vlax-ename->vla-object e))
(setq e0 (entlast))
(entdel e0)
        (foreach a lstr0
        (setq dh (/ a w)
                pa (mapcar '+ p1 (list 0 dh))
                pb (mapcar '+ p1 (list w dh))
                tm (mkline (mapcar '- pa (list 10 0)) (mapcar '+ pb (list 10 0)))
                pts (2epi tm e 0)
                pm (mid (car pts) (last pts))
                pm1 (mapcar '- pm (list 0 (* 0.5 dh)))
        (vl-cmdf "boundary" "a" "b" "n" e tm "" "" pm1 "")
        (setq m1 (entlast)
                ar1 (Vlax-Get (Vlax-Ename->Vla-Object m1) 'Area )
                dx (- a ar1)
                dd (/ dx w 2.)
        (while (not (equal dx 0 1e-3))
        (mapcar 'entdel (list tm m1))
        (setq pa (mapcar '+ pa (list 0 dd))
                pb (mapcar '+ pb (list 0 dd))
                tm (mkline pa pb)
                pts (2epi tm e 0)
        (setq m1 (entlast)
                dx (- a ar1)
                dd (/ (abs dx) w 2.)
        (vl-cmdf "boundary" "a" "b" "n" e tm "" "" (mapcar '+ pm (list 0 (* 0.5 dh))) "")
(mapcar 'entdel (list e tm m1))
(setq e (entlast)
        h1 (abs (p2ld p1 pa pb))
        p1 (mapcar '+ p1 (list 0 h1))
        lm (cons pts lm)
(mapcar '(lambda(x) (mkline (car x) (cadr x))) lm)
(mapcar 'entdel (list e e0))
(setq ssn (new_ss ee))
(vl-cmdf "_.rotate" e0 ssn "" pc (- (- 90. angint)))
(mapcar 'setvar '("cmdecho" "osmode") odlst)
试试看 参考
bssurvey + 1 赞一个!
回复 支持 2 反对 0
发表于 2008-12-16 19:39:00 | 显示全部楼层
cass有这个功能
GMT+8, 2025-5-1 04:03 , Processed in 0.566392 second(s), 31 queries , Gzip On.
