请论坛各位高手帮帮忙,这个程序只能修改尺寸标注的值却不能还原尺寸的实值 下面是程序的源码: (setq txt1 "") (defun editdim () (princ "\n选择需修改的标注 :") (setq p (ssget)) (command "dimedit" "n" dim2 "p" "") (setvar "cmdecho" 1) ) (defun editdimh () (princ "\n选择需修改的标注 :") (setq p (ssget)) (command "dimedit" "h" "p" "") (setvar "cmdecho" 1) ) (defun c:de (/ dim1 p dim2) (setvar "cmdecho" 0) (princ "\n请输入标注字符,允许汉字和空格。(空格->还原)(空回车->缺省值)<") (princ txt1) (setq dim1 (getstring T ">:")) (cond ((= dim1 " ")(editdim)) ((= dim1 "")(setq dim2 txt1)(editdim)) ((= dim1 "H")(editdimh)) ((setq txt1 dim1)(setq dim2 dim1)(editdim)) ) )
