查看: 1733|回复: 1
布局间的切换
发表于 2008-12-2 15:47:00 | 显示全部楼层 |阅读模式
在这个帖子http://bbs.mjtd.com/forum.php?mod=viewthread&tid=57581
ThisDrawing.SetVariable "CTAB", Layout.Name可以实现布局之间的切换?
在命令行中
输入setvar,再输入Ctab就可看到布局状态了。
输入“模型”,“布局1”或“布局2”就到了相应的layout中.
  1. Sub lls()
  2.    Dim objLayoutArray As Variant, objViewArray As Variant
  3.    'objLayoutArray = Array("主视图", "俯视图", "左视图", "西北等轴测视图", "西南等轴测视图", "东北等轴测视图", "东南等轴测视图", "多窗口打印", "任意角度")
  4.    objLayoutArray = Array("主视图", "俯视图", "左视图", "西北等轴测视图", "西南等轴测视图", "东北等轴测视图", "东南等轴测视图")
  5.    objViewArray = Array("Top", "Top", "Left", "NwISO", "SwISO", "NeISO", "SeISO")
  6.    For ii = 0 To UBound(objLayoutArray)
  7.      ''
  8.      tt = "(command ""Layout"" ""S"" "
  9.      tt = tt & Chr(34) & objLayoutArray(ii) & Chr(34) & ")" & vbCr
  10.      ThisDrawing.SendCommand tt
  11.      ''
  12.      tt = "(Command ""Zoom"" ""E"")" & vbCr
  13.      ThisDrawing.SendCommand tt
  14.      ''
  15.      tt = "(Command ""MsPace"")" & vbCr
  16.      ThisDrawing.SendCommand tt
  17.      Dim ObjLayerArray
  18.      ObjLayerArray = Array("粗边框线", "细边框线", "标题栏", "粗实线", "细实线", "尺寸线", "中心线", "剖面线", "Defpoints", "文本", "虚线", "点划线", "主材料表", "件号标注线")
  19.     Select Case objLayoutArray(ii)
  20.        Case "西北等轴测视图", "西南等轴测视图", "东北等轴测视图", "东南等轴测视图"
  21.          For jj = 0 To UBound(ObjLayerArray)
  22.            tt = "(Command ""VPLayer"" ""F"" "
  23.            tt = tt & Chr(34) & ObjLayerArray(jj) & Chr(34) & ")"
  24.            ThisDrawing.SendCommand tt & vbCr & vbCr & vbCr
  25.          Next jj
  26.      End Select
  27.
  28.      ''
  29.      tt = "(Command ""-View"" "
  30.      tt = tt & Chr(34) & objViewArray(ii) & Chr(34) & ")" & vbCr
  31.      ThisDrawing.SendCommand tt
  32.    Next ii
  33.
  34. End Sub
发表于 2012-6-19 16:56:14 | 显示全部楼层
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            doc.SendStringToExecute("layout s 布局2\r",false,false,false);
GMT+8, 2025-5-29 05:54 , Processed in 0.134924 second(s), 24 queries , Gzip On.
