楼主: luowy
[讨论]绘制多条线段
 楼主| 发表于 2008-10-20 14:43:00 | 显示全部楼层
(defun c:aaa()
(command "_mline" "st" "3气" "pause")
(while (= (logand (getvar "CmdActive") 1) 1) (command pause))
(command "explode" (entlast) "")
  (setq ll (cons 8 "0")
 yl (cons 8 "1")
 ysl (cons 8 "2")
 zkl (cons 8 "3")
 ;ol (cons 62 1)
  (setq ss (ssget "p"))  ;获得选集
  (setq n 0)
    (repeat (sslength ss)
    (setq ents (entget (ssname ss n))
          pp (cdr (assoc 62 ents)))
     (cond
 ((= pp '1)  (entmod (subst yl ll ents)))
 ((= pp '6)  (entmod (subst zkl ll ents)))
 ((= pp '230)  (entmod (subst ysl ll ents)))
      ;(entmod ents)
      (setq n (1+ n))
      );repeat
(defun *error* (msg)
  (princ "Failure at:")
  (princ msg)
  (princ))
如上可以解决问题,谢谢各位的帮助~~
GMT+8, 2025-7-31 16:24 , Processed in 0.153611 second(s), 19 queries , Gzip On.
