查看: 2341|回复: 1
关于autocad点的坐标
发表于 2008-10-6 22:15:00 | 显示全部楼层 |阅读模式
我想描等直线图从而得到很多组点的坐标,但是一个一个记录太麻烦了,用LIST命令也比较麻烦,有没有办法把这些点的坐标直接自动形成一个坐标文件?
发表于 2008-10-8 19:33:00 | 显示全部楼层
仅仅是个例子
(defun C:DR (/ cdate rq ct named filename name f s aa a z )
(setq named (vl-filename-base (getvar "dwgname")))
(setq filename (getvar "dwgprefix"))
(setq name (strcat filename named "点.dat"))
 (setq S (ssget (list (cons 0 "POINT"))))
(if s (progn
(setq f (open name "W"))
(setq aa (itoa (sslength s)))
(princ aa f)
(princ "\n" f)
(setq a 0)
(repeat (sslength s)
(setq z (entget (ssname s a)))
(setq pt1 (cdr (assoc 10 z)))
(setq z1 (caddr pt1))
(setq x1 (rtos (car pt1) 2 3 ))
(setq y1 (rtos (cadr pt1) 2 3 ))
(setq n (+ a 1))
(princ n f)
(princ ",," f)
(princ x1 f)
(princ "," f)
(princ y1 f)
(princ "," f)
(princ z1 f)
(princ "\n" f)
(setq a (1+ a ))
(close f)
(princ (strcat "一共有" (itoa a) "个点写入" name "文件内。"))
)(alert"选择集不存在或输入有误!"))
GMT+8, 2025-5-1 15:54 , Processed in 0.193425 second(s), 28 queries , Gzip On.
