楼主: smartstar
[求助]请高手帮忙修改一个lisp【已解决】
发表于 2010-4-20 14:08:00 | 显示全部楼层
zenme you de huifu kan bu dao ya
发表于 2012-8-20 11:19:26 | 显示全部楼层
我也正需要这个代码!
发表于 2012-8-20 11:21:00 | 显示全部楼层
试试 楼主的代码 可不可以用!
发表于 2016-4-13 09:10:09 | 显示全部楼层
(vl-load-com)
(defun C:VQ ( / ss Ent Entlist Lay)
        (setvar "CMDECHO" 0)
        (if (equal (getvar "TILEMODE") 0)
                (cond
                        ((equal (getvar "CVPORT") 1)
        (princ "\n 请双击激活视口运行本程序")
                        (T
                                (if (progn (princ "\选择视口内要冻结的图层上的对象: ")
                                                        (setq ss (ssget))
                                                ) (progn
        (setq i 0)
                                                        (repeat (sslength ss)
        (setq Ent (ssname ss i)
        Entlist (entget Ent)
        Lay (cdr (assoc 8 Entlist))
        i (1+ i))
        (command "vplayer" "f" Lay "" "")
                (princ "\n 请切换到布局")
        (setvar "CMDECHO" 1)
发表于 2016-7-2 16:12:44 | 显示全部楼层
我也需要啊
GMT+8, 2025-5-2 13:07 , Processed in 0.149367 second(s), 17 queries , Gzip On.
