帖子
查看: 1436|回复: 4
[求助]实现斜标注?
发表于 2008-9-24 11:14:00 | 显示全部楼层 |阅读模式
怎么用程序控制标注实现斜标注?
怎样才能将标注中的竖线变成斜线???
先谢谢了
 楼主| 发表于 2008-9-24 11:16:00 | 显示全部楼层
E:\delphi设计\桥面铺装\a.dwg
怎么用程序控制标注实现斜标注?
怎样才能将标注中的竖线变成斜线???
先谢谢了
 楼主| 发表于 2008-9-24 11:20:00 | 显示全部楼层
怎么用程序控制标注实现斜标注?
怎样才能将标注中的竖线变成斜线???
先谢谢了
发表于 2008-9-24 15:28:00 | 显示全部楼层
' 创建出同dli命令创建的一样的标注
Sub AddDimRotated()
    Dim dimObj As AcadDimRotated
    Dim point1 As Variant
    Dim point2 As Variant
    Dim location As Variant
    Dim rotAngle As Double
    Dim rotAngleNunmer As Integer
    rotAngleNunmer = 1
    With ThisDrawing.Utility
        point1 = (.GetPoint(, "请指定标注起始点(按Esc或Enter或左健退出):"))
        If IsEmpty(point1) Then Exit Sub
    End With
        point2 = (.GetPoint(, "请指定标注结束点(按Esc或Enter或左健退出):"))
        If IsEmpty(point2) Then Exit Sub
    End With
        location = (.GetPoint(, "请指定标注基准点(按Esc或Enter或左健退出):"))
        If IsEmpty(location) Then Exit Sub
    End With
    On Error Resume Next
    rotAngleNunmer = ThisDrawing.Utility.GetInteger(vbCrLf & "输入标注位置 [上(1)/下(2)/左(3)/右(4)]: <" & rotAngleNunmer & ">:")
    Select Case rotAngleNunmer
        Case 1, 2
            rotAngle = 0
        Case 3, 4
            rotAngle = 90
    End Select
    rotAngle = rotAngle * 3.141592 / 180#       ' covert to Radians
    Set dimObj = ThisDrawing.ModelSpace.AddDimRotated(point1, point2, location, rotAngle)
End Sub
 楼主| 发表于 2008-9-26 08:43:00 | 显示全部楼层
实现不了,主要是标注中的竖线变成斜线
GMT+8, 2025-7-13 05:13 , Processed in 0.165207 second(s), 23 queries , Gzip On.
