查看: 1824|回复: 4
请问出现这样的问题该怎么办啊??????????拜托,一定要帮忙啊
发表于 2003-5-26 17:02:00 | 显示全部楼层 |阅读模式
Compiling...
entity.cpp
C:\Program Files\ACAD2000\adsrx\sample\entity\entity.cpp(93) : error C2660: 'createNewGroup' : function does not take 3 parameters
一定要救我啊
我只有一天时间了
程序如下:AcDbObjectId createNewLine();
AcDbObjectId createNewCircle();
AcDbObjectId createNewLayer();
void createNewGroup();
Acad::ErrorStatus changeColor(AcDbObjectId,Adesk::UInt16);
AcDbObjectId
createNewLine()
        AcGePoint3d startPoint(5.0,4.0,0.0);
        AcGePoint3d endPoint(15.0,10.0,0.0);
        AcDbLine *pLine=new AcDbLine(startPoint,endPoint);
        AcDbBlockTable *pBlockTable;
        acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBlockTable,AcDb::kForRead);
        AcDbBlockTableRecord *pBlockTableRecord;
        pBlockTable->getAt(ACDB_MODEL_SPACE,pBlockTableRecord,AcDb::kForWrite);
        pBlockTable->close();
        AcDbObjectId lineId;
        pBlockTableRecord->appendAcDbEntity(lineId,pLine);
        pBlockTableRecord->close();
        pLine->close();
        return lineId;
AcDbObjectId
createNewCircle()
        AcGePoint3d center(10.0,7.0,0.0);
        AcGeVector3d normal(0.0,0.0,1.0);
        AcDbCircle *pCirc=new AcDbCircle(center,normal,4.5);
        AcDbObjectId circleId;
        pBlockTableRecord->appendAcDbEntity(circleId,pCirc);
        pCirc->close();
        return circleId;
AcDbObjectId
createNewLayer()
        AcDbLayerTable *pLayerTable;
                ->getSymbolTable(pLayerTable,AcDb::kForWrite);
        AcDbLayerTableRecord *pLayerTableRecord=new AcDbLayerTableRecord;
        pLayerTableRecord->setName("MYNewLayer");
        AcDbObjectId pLayerId;
        pLayerTable->add(pLayerId,pLayerTableRecord);
        pLayerTable->close();
        pLayerTableRecord->close();
        return pLayerId;
void
creatNewGroup(AcDbObjectIdArray & objIds,char *pGroupName,AcDbObjectId  pLayerId)
        AcDbGroup *pGroup=new AcDbGroup(pGroupName);
        for(int i=0;i<objIds.length();i++){
                pGroup->append(objIds);
        AcDbDictionary *pGroupDict;
        acdbHostApplicationServices()->workingDatabase()->getGroupDictionary(pGroupDict,AcDb::kForWrite);
        AcDbObjectId pGroupId;
        pGroupDict->setAt(pGroupName,pGroup,pGroupId);
        pGroup->setLayer(pLayerId);
        pGroupDict->close();
        pGroup->close();
Acad::ErrorStatus
changeColor(AcDbObjectId entId,Adesk::UInt16 newColor)
        AcDbEntity *pEntity;
        acdbOpenObject(pEntity,entId,AcDb::kForWrite);
        pEntity->setColorIndex(newColor);
        pEntity->close();
        return Acad::eOk;
void
runIt()
        AcDbObjectId newLayerId=createNewLayer();
        AcDbObjectIdArray idArray;
        idArray.append(createNewLine());
        idArray.append(createNewCircle());
        changeColor(idArray.first(),1);
        changeColor(idArray.last(),3);
        createNewGroup(& idArray,"MyNewGroup",newLayerId);
void
initApp()
        acedRegCmds->addCommand("ASDK_MAKE_ENTITIES","MSDK_MakeNewEnts","MakeNewEnts",ACRX_CMD_MODAL,runIt);
void
unloadApp()
        acedRegCmds->removeGroup("ASDK_MAKE_ENTITIES");
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg,void* appId)
        switch (msg){
        case AcRx::kInitAppMsg:
                        acrxDynamicLinker->unlockApplication(appId);
                        acrxDynamicLinker->registerAppMDIAware(appId);
                        initApp();
                        break;
        case AcRx::kUnloadAppMsg:
                unloadApp();
                return AcRx::kRetOK;
发表于 2003-5-26 22:34:00 | 显示全部楼层
前面声明void createNewGroup(); 时就应该把参数也写上啊!
你程序第四行应该写成void creatNewGroup(AcDbObjectIdArray & objIds,char *pGroupName,AcDbObjectId  pLayerId);
这样程序编译才能通过啊!
你前面声明是void createNewGroup(); 后面函数定义又带有三个参数,编译时当然会告诉你“createNewGroup' : function does not take 3 parameters ”啦!
 楼主| 发表于 2003-5-27 09:41:00 | 显示全部楼层
谢谢,但是又有新问题了
又有了新的错误啊
C:\Program Files\ACAD2000\adsrx\sample\entity\entity.cpp(93) : error C2065: 'createNewGroup' : undeclared identifier
Error executing cl.exe.
entity.arx - 1 error(s), 0 warning(s)
发表于 2003-5-27 11:17:00 | 显示全部楼层
程序错误原因:
第一,createNewGroup()函数声明与调用拼写不一致。你将该函数声明为void creatNewGroup(),而调用时用createNewGroup(),差一个字母e。不幸的是,你在程序开头将createNewGroup()函数声明为无参数的,再次写该函数的实现时,想要为该函数增加一个重载版本,但拼写错误使系统在调用时,只能找到无参数的函数版本,从而编译系统报告该函数不能使用三个参数。
第二,修改拼写错误后,编译仍有问题,系统报告第一个参数不能进行参数类型转换。这个错误大概是因为你对C++函数调用时参数传递机制的理解还有偏差。参数&idArray实际上只是一个AcDbObjectIdArray类型的指针,它不能转换为对AcDbObjectIdArray的地址引用。我将你的runIt()函数改写成这样:
void runIt()
  AcDbObjectIdArray* idArray=new AcDbObjectIdArray();
  idArray->append(createNewLine());
  idArray->append(createNewCircle());
  changeColor(idArray->first(),1);
  changeColor(idArray->last(),3);
  createNewGroup(*idArray,"MyNewGroup",newLayerId);
以上代码在VC6和VC++.NET中编译通过,且无任何警告信息。请注意我做的几处改动:
1、将idArray声明为指针。并用new运算符调用类AcDbObjectIdArray的构造函数给指针初始化。虽然VC编译系统并不要求你必须这样做,但一个未初始化的指针可能给程序带来的隐患不知你是否理解。关于这一点,一般高级点的C/C++教程应该都会提到。
2、既然idArray为指针,调用AcDbObjectIdArray类的成员函数就应该用 -> 运算符代替 . 运算符。
3、createNewGroup()函数的第一个参数用*idArray来传递数组的首地址。
要写好ARX程序,希望你能真正理解以上改动的必然性和其中的原理。有什么问题可以再发帖子询问。不过,有关C/C++的问题不妨到“源码分析”区提问。
 楼主| 发表于 2003-5-27 14:19:00 | 显示全部楼层
多谢,多谢
实在是太感谢了
你救了我一命啊
GMT+8, 2025-5-14 00:29 , Processed in 0.178294 second(s), 24 queries , Gzip On.
