查看: 1357|回复: 3
请教怎么才能制作一个自动加载工具条的程序?
发表于 2008-8-21 17:20:00 | 显示全部楼层 |阅读模式
最好发段源码上来参考参考!
发表于 2008-8-21 17:24:00 | 显示全部楼层
这是一段加载菜单的代码,照葫芦画瓢能做到么?
;加载菜单
(defun XG_MNU_LOAD ( / grp mnus file mnu tbars tbar)
  (setq grp "XG")
  (setq mnus (vlax-get-property *ax:AcadObject* 'MenuGroups))
  (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-Item (list mnus grp)))
    (if (setq file (findfile "XG_TOOLBAR.mnu"))
      (vlax-invoke-method mnus 'Load file)
  );if
  (if (not (vl-catch-all-error-p (setq mnu (vl-catch-all-apply 'vla-Item (list mnus grp)))))
      (setq tbars (vlax-get-property mnu 'Toolbars))
      (if (not (vl-catch-all-error-p (setq tbar (vl-catch-all-apply 'vla-Item (list tbars "1:500地形图修改工具")))))
 (vlax-put-property tbar 'Visible :vlax-true)
      );if
  );if
 楼主| 发表于 2008-8-21 17:29:00 | 显示全部楼层
willsnow1982
谢谢这位大侠的不吝赐教!我研究一下,有不懂的再请教你!
 楼主| 发表于 2008-8-21 20:21:00 | 显示全部楼层
willsnow1982
你的这个自定义函数好像有错吧,是否还需配合别的函数,请指教一下!
GMT+8, 2025-8-1 13:36 , Processed in 0.199059 second(s), 26 queries , Gzip On.
